Towbar Woes
- UrbanFlow
Towbar Woes
Hello all, I wonder if anyone can advise/help…
I bought my E70 back in March and it has a Brink/Thule detachable swan neck tow bar and flip down electrics.
Great I thought. As we have a tow bar mounted bike rack which we use when camping etc.
Anyway, long and short of it is, we haven't used it since we bought it and this weekend I fitted it for the first time.
The swan-neck detachable towbar was a tight fit, but it slotted in - but now I can't release it and get out. It's stuck solid. Press in and turn the knob and nothing releases. Argh!
To top it off I flipped down the plug in electrics and connected the bike rack - Blackpool Illuminations! - everything on even when the car is locked!
Indicators are also flashing on the wrong sides. Brake lights permanently on!
Any ideas or shall i just throw the car at the nearest towbar fitter/fixer?!
Current Rides:
Previous Ride:
2003 Silver 3.0i Sport E53 X5
Previous Ride:
- Don Coffey
Re: Towbar Woes
[quote="UrbanFlow"]
Not sure if I've understood you correctly, but when releasing the Towbar from the car, as well as turning the knob, you have to pull it out, so that you sort of pull the knob towards the offside of the car as you turn. The knob then locks out in this position and the Towbar should drop down. When fitting the Towbar, the knob needs to be in this position and once forced into position, the knob releases and the Towbar is locked in.
Don
Ok, 535dboy, let me have it!
Don
Re: Towbar Woes
I can't find any instructions on line for this one.
Sounds like the wiring is non-standard too, or hasn't used a matching compatible kit. Is it 7 or 13-pin?
The diagram below is how a 13-pin should be wired up. Check it with a meter.
As Don says, the OEM (Westfalia) bar is a pull and twist to 'arm' the lock and the same to unlock it.
- Don Coffey
Re: Towbar Woes
Thanks Richard, discribed so much better than example.
Don
Don
Re: Towbar Woes
No prob Don. How's the 'fling wing' job going?
R
R
- Don Coffey
Re: Towbar Woes
R
Plodding on. It's a requirement of the oil and gas sector that I need to gain 50hours offshore experience before I'm fully cleared on the line and so far I've only managed 30 hours in the last three weeks and only one 3 hour flight this week so very frustrating. Hopefully all will be sorted in early October.
That aside, I'm really enjoying the flying and looking forward to winter closing in, as that's when you really get to earn your money in the high winds, snow and ice.
Don
R
Don
Re: Towbar Woes
[quote="Don Coffey"]
...looking forward to winter closing in, as that's when you really get to earn your money in the high winds, snow and ice.
Don
A bit of turbulence eh..... :puke: :puke:
Don
- Don Coffey
Re: Towbar Woes
Don
True, but the passengers are used to it with very few actually being sick.
Don
Don
Don
- UrbanFlow
Re: Towbar Woes
[quote="UrbanFlow"]
Don
This BRINK towbar I inherited tells me to push in and twist down then pull the tow bar to release.
Having looked underneath it seems to be a really tight fit and the little stainless steel release catch isn't releasing.
[quote="UrbanFlow"]
Don
Current Rides:
Previous Ride:
Previous Ride:
- UrbanFlow
Re: Towbar Woes
Hello Richard,
I have 7 pin electrics - so it's been fitted for a tow bar mounted bike rack etc - which is what I'm using it for.
On closer inspection the electrics have been bodged in the boot to the wiring loom using blue block connectors instead of using a proper module. Grrrr!
To top it off, the green r/h wire is wired to the left indicator. What a mess!
Hello Richard,
Current Rides:
Previous Ride:
Previous Ride:
Re: Towbar Woes
Try a bit of WD40 on it. Mine is kept greased and I keep a surgical glove over the attachment pin to keep it absolutely clean.
Sounds like the fitter was colour blind as well as a Stetson wearer......yee haw!!
