Near side front tyre outer edge worn
celica
Perfectly good tyre but the outer shoulder on front near side has worn completely
Anyone else have this issue?
Would it be a MOT failure?
Pics to follow
Pics to follow
martin33100
Re: Near side front tyre outer edge worn
[quote="celica"]
Pics to follow
[/quote]Alignment could be out, we had the same issue with ours but we lost both front tyres through bad alignment.
The MOT spec is the middle 3/4 of the tread needs to be 1.6mm or above, the edges can actually be bald but you can't have and cords showing.
Pics to follow
- 535dboy
Characteristic of the car...........you wanted a good handling 4x4, there is your price !
The one to really look out for is the inner edge of the rear tyres
That isn't an MOT failure
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
celica
thanks
i'll get the front suspension arms checked out and then tracked/ alignment done
Nine468
As has been said above the geo seems to be out.
My guess is its got too much toe in on the fronts...
As the camber cant be adjusted.
The rears are a whole different thing, being adjustable for both camber and toe.....
Dave W.
BMW G05 X5 40D
BMW G05 X5 40D
celica
Rears have been done recently accordingly to the seller
Happy with tyre wear at the back
But for the fronts should I go laser alignment at £30 if adjustments required
Or same place does hunter for £30 front and then £18 per adjustment at the rear?
Nat
That's normal. Mine went after 10K miles. Rears are fine. Ive had my car from new , but went and had the tracking checked. It was within spec. Asked the guy to tweek it a bit see if the next set last longer. Seems to me the E70 doesn't eat rear tyres like the E53 did , but it does like a front one.
That tyre wont be an MOT failure unless the layer beneath starts to show.
Regards,
Nat.
Regards,
Nat.
celica
Thanks for the response
Had a hunter alignment done
Its in tolerance which I was surprised as it pulls to the left
Needing the toe adjusted but wasn't possible with the part seized up so getting new tie rod assembly's fitted
mark hamster 28
[quote="celica"]
QUESTION- I take it this is front tyres BUT my question can be front or rears, here goes.! If they wearing on outer edges like that, can you swap the tyres over ? obviously only on the same axle.! then you going to get better wear out of tyre ? Most tyres now directional but if you swapping on same axle is this ok ??
then the outside will become the inside on the other wheel and ditto ???
Last edited by mark hamster 28 on Fri Sep 26, 2014 10:21 pm, edited 1 time in total.
::) X5 M Sport F15 3.0D M Sport ::)
PREV-
New Model X1 Xline 2.0 D 2015
X 5 M Sport 3.0 D (E70) Only been gone 2 days but missed
Ford Focus ST3
Audi A4 Cab Final Edition
Range Rover Sport HSE
PREV-
Ford Focus ST3
Barney
If you swap them 'on the same axle' then surely a directional tyre would be going backwards ?
It would indeed.
mark hamster 28
yes, BUT as I tried to state, if you put what was the kurb side on the other wheel but don't put it on the kurb side, it will be going same way still ?or let me put it another way. On these tyres, is there only 1 side of the tyre (the tyre wall) that is to be a kurb side ? or look at it this way O:-) if you stand at the back of the car and imagine by magic you could just slide the tyre across to the other side and vise versa :blink: :blink: god now I'm getting confused lol
PREV-
Ford Focus ST3
PREV-
Ford Focus ST3
Barney
Bloody hell, you've confused me
) The only way would be to have the tyre re-fitted, not a great idea as the tyre will wear quick due to the direction of the wear 'peaks' being changed.
