Using the AV out on rear of arm rest?
Roy2593
Hi all,
Has anyone used the AV out for viewing the TV in the rear of your car? Is it as easy as plugging in a 3.5mm jack connected to the rear monitors via rca phono leads?
Thanks,
Roy.
Thanks,
Roy.
- bullethead
Re: Using the AV out on rear of arm rest?
Nope....Awaiting Sanj for definitive answer
- Sanj
Yes.
Or you can get more pro and splice into the switch and put one/two phono connectors in, so the rear screen connections can plug into it. Remember to go for the AV out - front screen gets the signal and passes it 'ou' to the rear screens...
(Oi - bullethead you ugly sod, best not be getting that M3! SMG box is big bucks if it goes wrong!)
Roy2593
Hi Sanj, what do you mean by splicing into the switch?
- Sanj
Open the switch up and you'll see 4 pairs of thin wires. They correspond to audio in, audio out, video in and video out. Just have to take a phono cable, cut the end off, take the inner and outer wires on it and join them to the video out (sorry, can't remember which one's, been a few years...). You can then take the phono connection from yourear headrest screens and connect them direct to your newly created connection.
OR - you can get one of these...
http://www.toysinyourcar.com/acatalog/bmw_av.html
My way is free and I'm as tight as they come!
Roy2593
When you say 'switch' do you mean the actual little AV panel on the rear of the arm rest? How do i go about getting into that mate to get to the wires?
I realy fancy doing that to be honest,a good idea!!
Cheers,
Roy
Cheers,
Roy
- Sanj
Yes that's what I mean by the switch. Open the armrest lid, take out the tray (just glued down) and you'll see two screws at the top next to the hinge arms.
Undo these and the whole back panel will come out (to the back, away from the vent). Voila, access to the switch and you can unlip it to make access a tiny bit easier.
I used a portale DVD player with an aux input/output to check which cables were which. No worry of blowing anything either - just watch you don't flatten the battery!
Good luck...
Good luck...
Roy2593
Nice one,i will try this! I tried putting a 3.5mm jack into the AV out into my screens (connected with rca plugs at the rear) i got a picture but got no sound!! Wonder why this is?
Any idea?
Roy
Any idea?
Roy
- bullethead
[quote=""Roy2593""]Nice one,i will try this! I tried putting a 3.5mm jack into the AV out into my screens (connected with rca plugs at the rear) i got a picture but got no sound!! Wonder why this is?
Any idea?
Roy[/quote]
Me too
Any idea?
Roy[/quote]
Me too
- Sanj
All to do with the cable you used!
They are different on the ends! I have two, one for Panasonic and one for Sony - one works and one doesn't...
Get a number of them from Maplins with the intention of returning them all once you've put them to good use.
Roy2593
I'm thinking of buying the phono lead adapter to plug in line with the TV module, but where is the TV module located?
Thanks, Roy.
Thanks, Roy.
It may be to do with the number of rings on your plug!! Ooh err.
Stereo leads only have three, AV leads should have at least 4 and sometimes the width of the ring can be the issue, other times it's what each one/s connected to.
Not 100% certain, but I thought the module was in the boot behind (nearest the rear) the battery under that black plastic cover?
Never anthropomorphise computers. They hate that.- kena
[quote=""Roy2593""]I'm thinking of buying the phono lead adapter to plug in line with the TV module, but where is the TV module located?
Thanks, Roy.[/quote]
It's in the boot under the spare wheel and black plastic cover, on the right hand side. It's the one with 2 plugs, 1 white and 1 blue.
- x555
In the boot mate under the spare wheel and german helmet next to the battery
here...
here...
Roy2593
Thanks guys, might order the cable as i have a spare phono cable running into the boot from ny screens!
Thanks again, Roy.
Thanks again, Roy.
