Shifter in M/S doesn't spring back to Park when P pressed?
Anyone else have this ?
Re: Shifter in M/S doesn't spring back to Park when P pressed?
[quote="celica"]
Hmm mine works fine with a single click of the P button
Agree, Hmmm! Car stopped, foot on the brake or handbrake on?
Also, does it jump to park from D or R when the engine is switched off?
Can't help any more I'm sorry to say.
Graeme
Graeme
No it stays in Park but doesn't spring back right
Get the fault codes read. Sounds like it could be the gear selector control box going by your other posts too.
People buy horsepower but drive torque!
I have seen this a few times at work it is normally a gear selector switch, I would agree with getting the faults checked to be safe. Hope this helps
03 carbon black edition 4.6is, champagne leather, sunroof, 20" 5 spoke, DSP
Suspected gear selector
Although looking at realoem and Indy flagging up it would be a replacement gear selector
Is there a replaceable switch?
If my understanding is correct the 'switch' is in the control box attached to the bottom of the gear selector so you end up with a whole new unit.
Looking at diagram it looks like whole new unit
