I know this topic has been covered so many times and i understand you will all be sick and tired of it.
However, My X5 40d is running on Bridgestone Dueler RFT and the rear tyres are due for replacement soon. The front ones have plenty of tread however are wearing on both outside edges. I tried putting higher pressure but the car seemed to bonce all over the road with higher pressure. It has M Sport suspension deletion which improves things i believe.
I am thinking of changing the whole lot for Michelin Latitude Sport 3. They are the same load rating as the originals but the speed rating is W on the rear and Y on the front. Will this matter ?
Also when changing to normal tyres, will the tyre pressure system work where i will be alerted if air is lost.
The non run flat Michelins are £100 cheaper than the run flat bridgestones and my car has 5 seats so i can get a spacesaver for the underfloor storage which is £260 from Bmw. Would it be worth swapping to non run flats? Is there any possible way to get rid of the outside wear on the front tyres ?
And finally do normal tyres last longer than run flats ?
Thank you in advance
