Noticed tonight when leaving work that the X5 40d when asked to reverse out of my slightly uphill bay on low throttle went all lurchy (like a car that thinks its stalling). And at the bottom of the work driveway also felt lurchy on light throttle pulling onto the roundabout.
Now when in drive i find this gearbox lazy in normal and like a cat on hot bricks in sport?
When warm i cant replicate the issue. Im in mid wales so its not the tundra for thick oil and no issues on check box thingy
Does anyone know of any common issues causing this? or has my dream of having a nice car end in gearbox replacement. :O. And btw i have shitty luck normally
Its a 10 plate LCI with the 8 speed box.
Lurchy when cold :o ideas and thoughts ?Autobox?
Woodenman
E70 40d Msport
Re: Lurchy when cold :o ideas and thoughts ?Autobox?
Not had that on mine, nor heard of any other owners with that sort of issue.
Woodenman
Going to run it past the garage i bought it from in the morning
Will also try a throttle reset tomorrow.
Its like a jerking feeling.
E70 40d Msport
- Steamyrotter
Could it possibly be a bit of brake bind??
Maybe a caliper sticking a bit??
Please note...
Please note...
Woodenman
Im not actually sure now its to do with the transmission.
I think its the engine running lumpy at cold start when i initially pop it into R or D and use very light throttle up to 1k rpm?
Its going for a diag tommorow and they are going to check its vitals.
:O
:O
E70 40d Msport
Woodenman
After diag and gearbox check they found a faulty glow plug relay that needs to be replaced? maybe this is why its only effected when cold.
E70 40d Msport
