Replaced glow plugs / controller as engine light came on the X5,
After that engine light on again and threw up EGR valve fault,
Local garage replaced egr and now the following fault codes thrown up [emoji35][emoji35]
Car is Defo in limp mode, struggles to go over 10mph with full pedal pushed!!
Mechanic now saying change the dpf pressure sensor - I'm not filled with confidence - anyone had same issue???
