Leak
pcdee
Leak
Post by pcdee » Thu Sep 17, 2015 6:46 am
Got in the Car this morning and saw a puddle in the passenger foot well.
Any ideas where it could come from?
X5 E70 3.0D SE
Reusch
Contact:
Re: Leak
Post by Reusch » Thu Sep 17, 2015 9:45 am
Have you got a panoramic roof ?
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
themoog
Re: Leak
Post by themoog » Thu Sep 17, 2015 2:31 pm
All that rain yesterday...
Nat
Re: Leak
Post by Nat » Thu Sep 17, 2015 3:56 pm
Ooooo , we all  love a mystery leak.
Sunroof, ( Blocked tubes that run down the windscreen pillars ) , Scuttle panel blocked ( its a very large area ) , worn/torn door seals , torn/shrunk door moisture barriers ( anyone had the door trim off recently ) are places to start. My money is the scuttle panel cavity.............
If there is antifreeze with it could be your heater matrix/valves/pipes.
Ive had great fun over the years finding these leaks.
Good luck
Nat
pcdee
Re: Leak
Post by pcdee » Fri Sep 18, 2015 4:23 am
[quote="Reusch"]
I have.....
X5 E70 3.0D SE
pcdee
Re: Leak
Post by pcdee » Thu Sep 24, 2015 8:05 am
Update......
I checked the drain holes by the sunroof and they are not clogged.  I tested the driver side just to see where it should exit the car.
So then I try the passenger side, the water just sits there, I checked under the car and there are just a couple of drops dropping slowly.
Could I get some compressed air in a can blow it through?
X5 E70 3.0D SE
stevox5
Re: Leak
Post by stevox5 » Thu Sep 24, 2015 9:29 pm
Hi there
Best thing to do is remove the inner A pillar trim (1 torx bolt under the airbag badge in the pillar trim)
You will then see the rubber drain tube running down the pillar into a metal tube just above the level of the dash, pull the rubber tube out and blow compressed air down the metal tube to clear the blockage at the bottom.
I did one last week and it was leaking so bad it ran water into the lamp control module that's mounted int the kick panel below the glove box , worth pulling that trim off and checking that control unit is dry.
Easy enough job
Good luck
X5 3.0i Topaz Blue , Paddle shift steering wheel , Pioneer double din sat nav,Alpine speaker upgrade,  Remap, HID's,20inch lemans alloys,lemans arch kit,Depo light kit,carbon fiber interior wrap.
pcdee
Re: Leak
Post by pcdee » Wed Sep 30, 2015 10:21 am
I can't see the tube
X5 E70 3.0D SE
