An Array of warnings / lights
Micevo
Re: An Array of warnings / lights
you can check voltage with the hidden features on your dash!!! will give you battery volts and charging volts its test number 9
paulcoles88
Will give that a go
So I'm looking for around 14V?
14.2 - 14.4V engine running. 12.6 engine off. If below 12V battery is dying.
paulcoles88
So I found the receipt for the current battery which was purchased in 2010, and as I'm still having random issues with it so I'm just going to go for a new battery.
Anyone have some good recommendations I've searched through posts but can't make sense of it.
This site suggested this battery.. https://www.tayna.co.uk/019-Enduroline- ... P8385.html
Does this look okay?
- fenj66
my s5 bosch is 4 years old now and showing around 11.8 volts standing and 13.8 engine running.
the car starts ok but ive noticed odd things happening with some electrics. as i still have the 5 year receipt i wonder weather euro car parts would agree its dying and replace it? O:-)
or if its worth accelerating its demise somehow! >:D
11.8 is too low if the car is asleep, but just about OK if awake. Should be at least 12.2 or better. Certainly sounds as if it is approaching its end. 13.8 is fine for non-AGM charging (they need 14.2-14.4).
paulcoles88
What is AGM i've seen some batteries listed as this?
Is there anything specifically i need to be looking for on a replacement battery?
I don't think ive ever had to replace a battery on a car
Absorbed Glass Mat. The (fibreglass) plates in the latest battery type have a special paste on them rather than large amounts of Suphuric Acid sloshing about surrounding lead plates. The work the same way and are safer. You need a higher charging voltage and the batteries are less tolerant of going flat but if looked after should be more reliable.
They give better performance under certain conditions and are becoming the de facto standard, particularly amongst the Start/Stop engine system manufacturers.
paulcoles88
I finally got the voltage info from the cluster
So just on ignition it was 12.1 fluctuating up and down give or take .1 or .2 then running it was going up and down from 13.2-13.5
and thank for the explanation, i guess I'm needing a new battery before it dies on me somewhere inconvenient.
Use a voltmeter, not the internal system. Measurements need to be made with the car asleep and four hours after last use.
john0459
Just had same problem with mine £124 for a new battery
