MOT Time
paulcoles88
MOT Time
So my X5 has her MOT this weekend, fingers crossed she passes :O although the headlight washers don't work but they aren't xeons just the standard halogen.. should this be okay? or am i going to have a nasty shock
Imy
Re: MOT Time
You will be fine
Re: MOT Time
MOT Manual only says they must work if fitted, in conjunction with HID (Xenon) or LED lighting units. You should be fine.
Section 1.7, para 2 in case of any query.
paulcoles88
Re: MOT Time
Thank you! you've put my mind at rest
You folks are so helpful
Thank you!!!
Thank you!!!
- Insight G40
X5-D-Sport
Re: MOT Time
I have HIDs fitted to mine... and the light washers have never worked & it always passes...
Re: MOT Time
You've been lucky with a tester not knowing the rules then. It should fail. Any good with lottery numbers?.....
Re: MOT Time
They never tested mine either, there's that many cars out there now with non projector headlights sporting HIDS, they must be going through the MOT test too. The testers Nate even commented on the colour of the light 600K , saying he liked them and where did I get them.
paulcoles88
Re: MOT Time
[quote="Insight G40"]
Did you pass?
I had to delay the MOT as i didnt get the bushes done quick enough
She was booked in for tomorrow but now the window has dropped and wont go back up so i dont know i think my X5 hates me
Did you pass?
paulcoles88
Re: MOT Time
She passed today but with a fair few Advisories...
Window still stuck down as they refused to look at it
Brake Pipe Slightly Corroded N/S & O/S Front
Headlamp Deteriorated but light output not reduced N/S & O/S
Tyre's close to limit N/S front, N/S & O/S Rear
Steering System has slight free play detected at steering wheel
Park Brake efficiency was only just met (17%)
So a nice little list to get sorted but the headlight washers werent a problem
Denis O
Re: MOT Time
[quote="paulcoles88"]
Brake pipes. Quick scrub with a wire brush and that's sorted.
Headlamp. Not an issue.
Tyres. I guess you knew they were knackered.
Steering. Can't be that bad.
Park brake. 16% is a pass. There's no point them going much beyond that as it's passed already.
Advisory's really piss me off. You have nothing to worry about and congrats on your pass.
05 Mercedes SL350
05 Mercedes SL350
paulcoles88
Re: MOT Time
Thank you!
It's always a worrying time getting an MOT
TimX5
Re: MOT Time
Mine passed last week with flying colours
