Egr blank/bypass 3.0 d e53
- toonarmy
How many people have blanked and passed mot ok ?
X5 e53 3.0d 53 plate and Honda vtr1000 fun time
Re: Egr blank/bypass 3.0 d e53
I fitted the bypass kit, xmas eve and its the best thing I have done to the thing. Got my mot in feb, so will let you know if it passes
2002 X5 3.0i gone
2002 X5 4.4i gone
2002 X5 3.0d Current Car
2002 X5 4.4i gone
- toonarmy
Which kit did you get I have ordered the straight through and blank plate to get rid of th pipe ?
I fitted the EGR AND blanked + removed the pipe from the manifold...
The MOT inspector isn't interested in what's fitted, simply what the emissions pump out
- toonarmy
Yes I know what you mean but the thread was asking has anyone had trouble passing an mot after removing it cheers
Ahhhh, I see...
Well, put it this way, my X5 diesel has done over 150,000 miles (EGR removed) & the emissions were cleaner than the ambient air, as I was informed by my MOT inspector.
He reckoned that If I had a suicide wish,
that
I would probably die of old age before Exhaust poisoning with a pipe from the exhaust into the vehicle
The EGR removal makes such a tinsy difference it is barely worth comprehension.
A good oil & filter change & a dose of injector cleaner will do far more than an EGR ever will.
Provided your Oil / Injectors / Engine are in good order, the EGR removal will not effect your MOT viability at all - ever.
that
- toonarmy
Thanks for replies egr blank kit arrived at home along with door carrier and scanner but I'm on hols in Scotland typical still keep me busy next week
- toonarmy
Fitted egr blank plate and straight through pipe will run her tomorrow see what difference there is has anyone done this fitted the blank plate and remover the whole pipe what did you do with the heat Sheild that was mounted on there? Cheers
The difference will be only just noticeable, and you will get a tad more MPG most likely too.
I left the shield in situ as I did mine between rain showers & had to hurry lol...
It's amazing how much junk you can chuck out from under a bonnet !!
