Anyone replaced Blower Unit and Blower Regulator ( noises from fan)
celica
Post by celica » Tue Feb 16, 2016 9:55 pm
I've been told my pulsating noise is due to the blower regulator item 5
And I've started to get a high pitch squeal when braking at times which I've been told is due the blower fan bearing gone and rubs against fixings due to angle, which is the blower unit item 4
celica
Re: Anyone replaced Blower Unit and Blower Regulator ( noises from fan)
Post by celica » Mon Feb 22, 2016 8:05 pm
Does it matter which part number is chosen or is it just production dates making them different?
Post by X5Sport » Tue Feb 23, 2016 5:47 pm
You will only be able to get hold of the current version - those not marked ENDED.
The 'ENDED' versions will have been replaced by an updated/modified variant as production continued to deal with problems with either the earlier version, mods to the other car parts around it, or perhaps a changed supplier.
celica
Post by celica » Tue Feb 23, 2016 6:03 pm
I've seen an ended item being listed on a website a lot cheaper and still new so maybe worth a go?
celica
Post by celica » Sun Feb 28, 2016 7:46 pm
Part 4 is c£180-200 new for the blower unit which looks like a fan
I think it's the part which moves air around
Any thoughts on a used item at £50 from a 2011 60k car, worth a punt as I still need the regulator which I'm thinking new and other spend on car which is all mounting up
libra007
Post by libra007 » Tue Mar 22, 2016 4:25 pm
did you end up replacing it? I might have the same issue
2009 X5 MSport
celica
Post by celica » Tue Mar 22, 2016 5:24 pm
I picked up a used LCI blower unit can and the regulator
Thought I'll take a gamble as was £60 for both
The squealing has gone but the pulsating is still an issue, although maybe not as bad but still more than noticeable
Regulators can be had quite cheap, not sure if to try a new one
I've read other treads some have had to try a few to resolve
