light problem
light problem
hi all this morning had in info center message ,check park lights, looked round n/s/f angel eyes not working but indicator on[not flashing]put headlights on indicator goes out as normal,could it be just the bulb in the angel eye,is there only one?and is it a special type or something i could get from a local factor as always thanks for any ideas
- Turks
- Contact:
Re: light problem
Hi,
Yeah the Indicator bulb comes on automatically to mark the side of the car when the side lights aren't working (angel eyes). If you get a replacement bulb everything will go back to normal.
You can get the replacements from the dealer for about a tenner or you could take the opportunity to upgrade to LED by buying some LED Markers lights from somewhere like HID's Direct. Do a search on here and you will find some information on it. IMO they look better but some people don't like the LED White.
Turks.
Turks.
Present:
Past:
Past:
- pvr
Re: light problem
I had indeed the same a few weeks back, replacement very easy.
I went with the HID direct.
I have a 10% discount code if you want it.
911 50th anniversary -
Re: light problem
thank you gentlemen, think i will go with standard,is it a special bulb for that price? but many thanks for the offer
- pvr
Re: light problem
It is a weird bulb and fitting. I would offer you my remaining standard old one, but it is obviously used and might not be worth your while.
- pvr
Re: light problem
Re: light problem
thanks all ,cannot believe the knowlegde thats out there,just going to replace with standard part for now,thanks all again
- Turks
- Contact:
Re: light problem
No Probs...
You can split the holder and replace the bulb but way too much time and trouble to save a £5!
Turks.
Turks.
Present:
Past:
Past:
- nando999
Re: light problem
Hi Guys,
My X5 cam up with the "check park light" about an hour ago, glad i found this message board. Does anyone know of a store in Birmingham where i can by the LED replacement bulb, i though i might take this opportunity to upgrade.
Thanks in advance.
Nando999
Thanks in advance.
Nando999
- Turks
- Contact:
Re: light problem
I think HID's Direct is in Manchester but if I recall correct it was next day delivery anyway... I'd just get them from their website and relax at home until they come!
Turks.
Turks.
Present:
Past:
Past:
Re: light problem
how do you get at the bulb for the angel eye i can see the cap forthe main beam but cant seem to see were the angel bulb is located,thanks
- Turks
- Contact:
Re: light problem
There is a rectangular cover on the back of the light unit with a red coloured seal (off memory). You need to remove this cover and inside you will find the bulb fitting for the angel eyes. The passenger side is quite tough to get to if I recall so start with drivers side so you have an idea what to do.
Turks.
Turks.
Present:
Past:
Past:
Re: light problem
thanks turks,found bulb removed unit , bought some led bulbs of ebay but cant see how they will fit so stripped holder apart and put new bulb in ,ahh the joys of motoring!!
- pvr
Re: light problem
Good result. The HID replacements I bought were a direct replacement.
- nando999
Hi Turks, I'm an impatient person so wanted it right away. Found a place in the midlands but wanted £55 for the LED bulbs, told them where to put it and ordered it from HID Direct.
I've taken the driver side bulb out and it looks considerably smaller than the LED replacement, will it fit without modification?
Thanks,
Nando999
Thanks,
Nando999
