Kitchen concrete floor.
General off-topic chat.
Mpower
Post by Mpower » Sun Sep 25, 2016 10:57 pm
Hi all,
Just started to rip old kitchen out and wanting to tile the floor,the question is do I put down some kind of insulation on the cold concrete floor before tiling?
Mpower
Update:
Was meant to update this thread awhile back,well here it is laid underfloor heating as suggested by fellow members and the wife is happy as can be,many thanks all!
sid10
Re: Kitchen concrete floor.
Post by sid10 » Mon Sep 26, 2016 10:08 am
Has it a damp course ? I once laid a tiled floor on concrete , next day they had all lifted up .
Check first if it has a damp course , if not I would think about laying something else ( I put down water resistant laminate with a foil backed underlay ) 6 years on still as good as new , no grout to bother with and warm on your feet !
Steamyrotter
Post by Steamyrotter » Mon Sep 26, 2016 1:11 pm
If you are re-concreting it then probably underneath the screed layer..
If not then there may end up too much movement to guarantee the tile staying put as the insulation will be spongey in comparison....
However saying that look into how the Americans do it.. as i believe they insulate and then put a layer of board down.
Ply or heavy duty backer board i think....
Youtube it..
Please note...
Mpower
Post by Mpower » Mon Sep 26, 2016 5:49 pm
[quote="sid10"]
It has a damp course but just wanted a warm floor to walk on and the missus wants a tiled floor can't have both without a thick insulating layer.
Mpower
Post by Mpower » Mon Sep 26, 2016 5:51 pm
[quote="Steamyrotter"]
Youtube it..
Will have a look but it may raise the floor too much?
Steamyrotter
Post by Steamyrotter » Mon Sep 26, 2016 7:50 pm
You could always put that undertile heating kit in the tile fix layer..
Please note...
pcdee
Post by pcdee » Mon Sep 26, 2016 9:23 pm
That's what I did on the ground floor as it's a concrete.
If your doing it make sure you use flexible adhesive.......expensive stuff but well worth it.  I done mine about 8 years back and still looking great.
X5 E70 3.0D SE
kjb1
Post by kjb1 » Sun Oct 02, 2016 1:16 am
We have karndean flooring, warm underfoot and rock solid.
Turks
Contact:
Post by Turks » Fri Oct 07, 2016 3:41 am
[quote="Mpower"]
As others have said, install a U/F Heating Kit for the space. I used a loose wire kit and laid it out myself. I then poured a 2-3mm layer of self levelling screed over the top to keep the wires in place, but to also make sure that the tiler didn't snag any of the wires when applying the tile adhesive. Great under foot, but costs a bit to run.
...or wear slippers.
Turks.
Present:
Past:
kena
Post by kena » Sun Oct 30, 2016 8:52 pm
[quote="kjb1"]
Excellent stuff..
Mars
Post by Mars » Sun Nov 20, 2016 11:49 pm
Karndean is your friend here - agree with other ops. Can't go wrong.
2014 3.0d M Sport (the snail)
