Door Handle Fix (E53)
How-To articles ONLY go here.
lezmtaylor
Re: Door Handle Fix (E53)
Post by lezmtaylor » Mon Sep 04, 2017 4:34 pm
Pelican Parts do loads of ' how to's' for different BMW  cars, it is an American site, but very helpful.
Lez
Insight G40
Post by Insight G40 » Mon Sep 04, 2017 9:15 pm
Many thanks, guys.
Going to order a Febi one, heard that some bay cheap ones can be useless and fit at weekend.
E53 Sept 2006 3.0D Sport
Post by Alan Gunn » Tue Sep 05, 2017 7:58 am
Lyons
Post by Lyons » Fri Sep 08, 2017 8:29 am
The photos in that pelican thread are great, thanks. I've an infuriating bass rattle in the drivers side door that I'm going to investigate and need to get the door card off to do so.
Anyone know the part number for the clips so I can have a few on stand by?
Post by Alan Gunn » Fri Sep 08, 2017 10:26 am
Did mine on Wednesday only took around 30 to 40 minutes easy job to do just waiting for a new handle now as someone had done a bodge job on the end that twists out it had been broken and a screw put in it badly.
As for the clips i got 10 of them in case ad delivery was quick.
http://www.ebay.co.uk/itm/10-x-BMW-3-5- ... 2749.l2649
Edit/Tip
Put mine back together and the locking didn't work turned out to be one of the plugs on the window switch.
It had gone in and the locking tab went over but it wasn't properly home but i did it the hard way by taking the panel off again before i found it could have just popped the switch out  :-[
sleepyfolk
Post by sleepyfolk » Fri Sep 08, 2017 4:59 pm
There are two different types listed for the door cards, BMW numbers are:
Clip with seal ring 51418224781 x 6 ,
Clip with washer 51418224768 - think there's a dozen or so on each door card
Door Handle Carrier  Left 51218243615
Door Handle Carrier Right 51218243616
The clips were cheap enough from Cotswold BMW on here, the last eBay ones I bought for the boot trim weren't quite the right size, so far I've found BMW ok on price for the little bits
Mercedes CLK 320
Audi A6 Quattro 2.4
Post by Alan Gunn » Fri Sep 08, 2017 7:06 pm
2 Fell out when i took the door card off and went under the car so out of my reach.
I used 2 out of the ones i listed and no problem fitted the same as the rest none are a tight fit easy to fall out.
Lyons
Post by Lyons » Fri Oct 20, 2017 11:06 am
I had my door card off at the weekend to investigate the door speaker fault and now the airbag light is on. I had the plug disconnected at the door while I had the ignition on (to check the speaker). I assume this is where I’ve gone wrong? I know on an Audi/VW if you turn the ignition on with an airbag disconnected it will put the light on,are BMW’s the same?
Post by Alan Gunn » Fri Oct 20, 2017 12:35 pm
[quote="Lyons"]
Yes
Should be able to turn it off with a scanner my c310 does it.
Lyons
Post by Lyons » Fri Oct 20, 2017 1:01 pm
Super, thanks. I'll just wait until its next in with the mechanic and let him do it. Unless it can be done with INPA.
Post by Alan Gunn » Fri Oct 20, 2017 1:26 pm
[quote="Lyons"]
You can.
https://www.youtube.com/watch?v=FONtjKicFNc
Lyons
Post by Lyons » Fri Oct 20, 2017 2:14 pm
Brilliant! Thanks very much.
Lyons
Post by Lyons » Sun Mar 04, 2018 8:06 am
Folks, my door handle still opens the door, but it can take 3 or 4 pulls before anything happens. Is this likely to be the carrier or could there be something else gone? From what I’ve read over the page everyone else’s handle has literally  just broken.
DavyBoy
Post by DavyBoy » Thu Mar 22, 2018 11:34 am
Hey all
I carried out the lock replacement as expertly pointed out in this feed, Thank you.
Initially all 4 doors locked and unlocked with the remote but the next day the central locking now only works for the remaining 3 doors, I find myself having to unlock/lock the drivers door with the key in the new lock?
I tried to resync the locking mechanism by the "ignition key to point 2 and the top then middle button of the remote control" and the method works but it remains just the 3 other days working off the remote.
Any ideas?
>:D
Sanj
Post by Sanj » Fri May 18, 2018 2:25 pm
Original pictures back on this thread too, will continue to check the others I did.
