OBC
OBC
Post by henrym3 » Tue Nov 07, 2017 8:18 pm
Tells me that the number plate lights aren't working, they are, removed lights they are very clean corrosion free, been in there a few years, no codes on scanner so can't clear. Still the same after key has been removed over night. How do I clear the OBC or what might be causing the problem. Touching battery leads together is last resort as have LPG tank fitted
VW R32 Gone
Smeeagain
Re: OBC
Post by Smeeagain » Tue Nov 07, 2017 10:39 pm
Well........ you just know that the battery is always the issue on these, but have you tried checking the fuse for corrosion too? Or charging the battery with a CTEK conditioner, or similar, before venturing forth with the lpg ..... ?
sleepyfolk
Re: OBC
Post by sleepyfolk » Wed Nov 08, 2017 12:22 am
This might be a long shot Henry but I had a few error messages with my back lights when I bought the car.
Although not a number plate light i was getting a tail/side light error, the actual lamp was working and in the end it turned out that although the light was illuminating when switched on - when I took the lamp out it looked like the actual filament wasn’t in the best condition, I bought a new lamp and the error went, so maybe it’s worth trying 2 new lamps as they’ll only be a few pence?
My brake light errors I cleared by soldering the tracks on the light fitting, not sure there’ll be anything like that on the number plate lights though.
Mercedes CLK 320
Audi A6 Quattro 2.4
Re: OBC
Post by henrym3 » Wed Nov 08, 2017 5:37 pm
sleepyfolk you may have hit the nail on the head, when I took the cover off again one row of the LEDs was out, last time I looked they were ok but perhaps were on the way out. not really noticeable by just looking at how the number plate was lit up. So I'm going with a couple of new LEDs. Probably doesn't help with all the boot slamming. They are those error free LEDs so will send for some tonight.
Smee I checked the fuses, always like to do the free stuff first, battery is in excellent health
VW R32 Gone
sleepyfolk
Re: OBC
Post by sleepyfolk » Wed Nov 08, 2017 6:37 pm
That’s good, LEDs eh? Very posh, I’m still on tungsten filaments!  :))
Mercedes CLK 320
Audi A6 Quattro 2.4
Re: OBC
Post by henrym3 » Fri Nov 10, 2017 9:16 pm
New LEDs fitted, problem solved, good call sleepyfolk.
VW R32 Gone
sleepyfolk
Re: OBC
Post by sleepyfolk » Sat Nov 11, 2017 12:56 am
Cool, nice when it works out as something simple!
Mercedes CLK 320
Audi A6 Quattro 2.4
