I've had this problem before but just want to check something before I talk to the dealer.
I went to open the driver's side door very carefully as I'm aware of the problem. It opened but didn't feel normal so I thought there might be a problem.
When I went to close it I couldn't so resorted to holding it shut and pressing the central locking button.
It won't open from the inside now either.
I've got out of the other side and just hope I can open that to get back in later.
Anyway, is it likely to have broken (again) or just be frozen? Before I start a warranty claim I thought I'd ask as I can't remember.
If it is broken although I have a warranty I feel a bit reluctant to pay the excess when this is a common and known problem. I think last time they initially tried to argue it as being trim and not covered but I'm not having that.
What's most annoying about this is it happens just as I am able to make use of the winter tyres and 4wd. The last thing I want to be doing is taking it to the garage or to no be able to safely drive it.
Winter door handle problem - again!
2004 E53 3.0D Sport
2016 F25 X5 35D MSport
Re: Winter door handle problem - again!
I would suggest the lock internal is frozen
I have similar problems, more worrying when the car initially moves, I have to turn out the drive and the door swings open and car goes into park all of a sudden!
Open the door and get some squirty lubricant spray into the latch, I’ve not had issues since
However
Your car may be different but worth a try!
However
I've had this problem before and have even resorted going through the boot when I have needed to get somewhere on time
Usually it is just the lock mechanism that is frozen, give it 20 mins of the car running and it should defrost. I need to take the door card off and spray the mechanism with a silicon lubricant, should displace the water/condensate building up around the lock/cables which is then freezing over night.
As above, I've also pulled off the drive only for my door to swing open and the car to slam itself into park
2009 BMW X5 30d XDrive M Sport
2004 BMW X5 3.0d M Sport .... Gone!
Thanks. Panic over. It's thawed out and now works. I was worrying as I know they have a tendency to break (which is why I'm very gentle with them in the cold).
2004 E53 3.0D Sport
The wifes car driver door always freezes internally. I can open the door but it wont stay closed. I get the heat gun on it for 5 min to defrost it. When its warmer ill take the door panel off and lube all the latch inside.
