How to replace front Tension Arm.
How-To articles ONLY go here.
Nige
Post by Nige » Mon Mar 07, 2011 9:13 am
I was suffering from vibration through the steering wheel from over 60mph. This is often caused by worn bushes on the front Tension arm (Item 7) or worn balljoints (Items 10 or 15) on the diagram below.
By laying on my back, grabbing the Tension arm in the middle and twisting, it was obvious the bush (#7) was worn as cracks in the bush could be seen when twisting it.
Bush #7 can be bought for about £35 and pressed into place, however I don`t have access to a suitable press and was short of time. 2 new Tension arms were £65 ea from my local motor factors.
Start by removing the front roadwheel and securing the car on axle stands.
Remove the small 8mm bolts holding the inner arch liner in place (many were rusted and needed a pair of mole grips to loosen them)
The arch can then be `peeled` back, this was easier than fully removing the entire liner. Once done, the brake duct needs removing by taking out the 4 screws. On the passenger side, the external air sensor is fitted to the duct, so be careful not to pull the wires out. The plastic guard over the steering arm was also remove to make access easier.
There is also a plastic clip that can be accessed from the front bumper with a screwdriver, the centre needed to be pulled out.
External air temp sensor can just be seen at the bottom right of the photo
Arch peeled back and wedged in place
The tension arm securing bolt.
Access for the nut is very tight, so I used a ring spanner to lock the nut.
Socket onto the Bolt
long bar is needed to loosen the bolt.
Once removed, place to one side.
The large nut holding the arm to the balljoint can be removed.
Ready for removal..
This is where a balljoint splitter is required. I didn`t have one large enough and had to manage with a 19mm one. It made the job much more difficult. on my car, this has been in situ for 90,000 miles and 6 years. It was `secure`... :headbang:
Some people hit the top of the arm with a large hammer and knock it off the balljoint, but I was reluctant to do this for fear of damaging the balljoint (#15) in the process.
I used a piece or bar to put tension on the balljoint frmo the balljoint splitter.
Hitting the end of the balljoint, whilt it is under tension did the trick for me. Each side probably took 30 minutes to actually remove the arm from the balljoint. They are tight, but DO come off with perseverance.
Once removed, it was immediately obvious how much the old bush had worn
New arm next to old one
Copperslip applied to balljoint taper to enable easier removal if needed in future..
.Image
Refitted the arm into the chassis mount
I then refitted the plastic trip, ensured everything was secure and repeated on the other side. The vibration is gone and the car sailed through the MOT.
Hope this helps.
Nige.
fenj66
Re: How to replace front Tension Arm.
Post by fenj66 » Mon Mar 07, 2011 9:29 am
thanks nige, excellent write up! very clear.
this will be very useful to many, as our cars are all getting on a bit now and will no doubt need these replacing at some point.
i note your using metrinch spanners, very useful for getting rounded off nuts/bolts off.
pvw10
Post by pvw10 » Mon Mar 07, 2011 9:33 am
Top man Nige, great job.
Paul
Nige
Post by Nige » Mon Mar 07, 2011 9:40 am
[quote=""fenj66""]i note your using metrinch spanners, very useful for getting rounded off nuts/bolts off.[/quote]
Yeah, it was the only one I had that fitted the nut (21mm I think), but they are useful for rounded bolts :)
As you say, our cars are getting on a bit and these sort of things will need doing. A proper sized balljoint splitter would have made the job MUCH easier. That was the hardest part.
lezmtaylor
Post by lezmtaylor » Tue Mar 08, 2011 9:07 am
That is a first class write up, another check point on my list of to do's.
Lez
storminmike
Post by storminmike » Tue Mar 08, 2011 8:52 pm
[quote=""lezmtaylor""]That is a first class write up, another check point on my list of to do's.
Lez[/quote]
agreed...brilliant
On the tool front please
What size sockets and spanners are required?
Ball joint splitter...would a pickle fork be better and if so how big
Plus....would you not consider replacing the ball joint too whilst it's in bits? The nuts on it look weird though
x555
Post by x555 » Thu Mar 10, 2011 11:34 am
Once again a great write up Nige and thanks for taking the time to do so :thumbsup: it's what makes this forum so great :D
Giles90
Post by Giles90 » Tue Jul 19, 2011 5:19 pm
great write up, I'm wondering if mine need doing.
The ride is pretty hard, sure this can't be right.
I've had 2 independents look at the bushes and tell me they're fine, but the ride is sooo hard. Is there a way to confirm for those of us who aren't technical?
2004 X5 4.4...to do - nothing! wheels refurbed, amplifier fixed, full MOT, living the dream!
E39 5er various AC Schnitzer mods - gone but not forgotten
macky
Post by macky » Tue Jul 19, 2011 6:23 pm
[quote=""Giles90""]great write up, I'm wondering if mine need doing.
I've had 2 independents look at the bushes and tell me they're fine, but the ride is sooo hard. Is there a way to confirm for those of us who aren't technical?[/quote]
Subframe bushes maybe? do you get a thump when setting off harshly?
Giles90
Post by Giles90 » Tue Jul 26, 2011 2:51 pm
Hi macky, thanks for coming back to me!
Yes I do get a bit of a thump, is that pretty conclusive?
Giles90
Post by Giles90 » Tue Jul 26, 2011 3:02 pm
I should maybe have said that I don't really get any noises though, I know some issues with worn bushes can cause knocking noises.
d8ean
Post by d8ean » Fri Aug 19, 2011 3:36 pm
ive had the bushes replaced with powerflex ones, but i still feel some sort of clunk / rattle from the front wheels...normally when going over speed bumps etc - is tension arm easy to see by laying under the car?
