Hi when i start up in the morning there is a swishing noise if you rev up to 1500rpm and over but not on tickover ? it sounds like a belt or pulley.
Just wondering if anyone can point me in the right direction.
Cheers Jason
E70 2011 40d
odd noise when engine is cold
neil50
Re: odd noise when engine is cold
If it is only when you rev and not on low tickover then I instantly think about things that speed up with the rev range such as belts or pulleys.jasonh1 wrote: Tue Mar 17, 2020 12:03 pm Hi when i start up in the morning there is a swishing noise if you rev up to 1500rpm and over but not on tickover ? it sounds like a belt or pulley.
Cheers Jason
E70 2011 40d
A "swish" though can be interpreted in many ways. Be careful of revving on a cold engine on startup as if you do it immediately there may not be sufficient oil in the turbo's to correctly lubricate. This is also why you shouldn't "floor it" on a cold engine as you are placing untold load through a turbo etc. that is not at peak working condition.
With the bonnet up and someone else on the accelerator, can you hear where in the engine bay the sound is coming from?
Neil
Current
2011 E70 40d 7 seat - remapped
Merc CLK convertible
Audi A2
Smart Car
Previous BMW
E32 - 735se, 735il
E39 - 530d touring
E61 - 525i touring, 525d touring (remapped)
Audi A2
Smart Car
Previous BMW
E32 - 735se, 735il
E39 - 530d touring
jasonh1
Hi Neil the noise is coming from the drivers side, ive taken the under tray off and wd40 all the pulleys just to check but made no difference,
- marti
Probably the turbines in the turbo......normal.
