Air Bag Warning Light
X5-D-Sport
Post by X5-D-Sport » Wed Sep 09, 2020 11:11 pm
A friends E53 D-Sport 2005, had a door speaker fail...
So we remove the door panel after disconnecting the battery in the rear.
Pulled all the connectors incl air-bag to get good access.
All was re-connected & re-assembled several times, but we cannot find a reason that the instrument cluster air bag warning stays on.
We have done all the tricks re the battery by shorting the cables together once removed from the battery etc, but the light stays on..
What are we missing / need to do ?
Any one experienced this before or know the answer ?
regards to all.
Grant B
Re: Air Bag Warning Light
Post by marti » Thu Sep 10, 2020 7:10 am
Did you disconnect both battery cables?...at anytime did you reconnect the battery with airbag still disconnected?
Greydog
Post by Greydog » Thu Sep 10, 2020 8:11 am
Don't quite follow why the airbag was disconnected as it doesn't interfere with speaker access or the tweeter at the back of the mirror.
As marti has pointed out the battery was probably reconnected ahead of the airbag or the airbag connector was not seated properly. Once the Airbag light has been triggered you will need diagnostics to fault read clear the fault and reset it.
Raj
Post by Raj » Thu Sep 10, 2020 8:37 am
Airbag removal shouldn't have been required but does sound like it's just triggered so need to get it plugged in to clear the fault and see if stays off. If it returns then might need to check the pins in the connector to make sure it's seated properly.
X5-D-Sport
Post by X5-D-Sport » Thu Sep 10, 2020 2:03 pm
the air bag module/part was removed to fit a replacement door handle, & then re-fitted.many thanks for the replies chaps.
Much appreciated
Raj
Post by Raj » Thu Sep 10, 2020 5:09 pm
X5-D-Sport Salisbury wrote: Thu Sep 10, 2020 2:03 pm the air bag module/part was removed to fit a replacement door handle, & then re-fitted.many thanks for the replies chaps.
Much appreciated
Ah ok makes sense now lol. Thought it strange for the speaker failure. Hopefully if you clear the error it should stay off now it's all connected upon again.
Post by Leslie » Thu Sep 10, 2020 10:30 pm
I unplugged the door airbag in my 330d years ago and had the battery disconnected at time to fit a window regulator but had to move window up to fit a screw so plugged airbag back in first but didn't put the little cap on the plug to lock it in , if you don't do this it still triggers airbag light I found as the pins are grounded :headbang:
X5-D-Sport
Post by X5-D-Sport » Thu Sep 10, 2020 11:21 pm
Hi Leslie,
what is this little plug you mention please ?
Post by Alan Gunn » Fri Sep 11, 2020 6:04 am
I did both jobs you did but i never disconnected the air-bag i just left it hanging.
Did you test the new speaker by any chance before putting it all back together ??.
Post by Leslie » Sat Sep 12, 2020 11:58 am
X5-D-Sport Salisbury wrote: Thu Sep 10, 2020 11:21 pm Hi Leslie,
It probably isn't fitted to newer cars was just a little locking clip you put on after pushing the plug in.
