Hi,first post and a question already ! I have just bought a lightly damaged 4.8is (needs a wing and a door),could do with knowing if there are any differences between a pre-facelift and a facelift door ?
Many Thanks
Facelift Doors
- Powercat
Re: Facelift Doors
Hi I think thay are likely to be the same, but I am sure one of the other members will confirm this,
are you a cat D or are you unregistered ?
don't forget to say hello properly in the Newbies introduce yourself section and post photographs
02 x5 3.0d auto cat D
Re: Facelift Doors
Unfortunately its a Cat D but is a very high spec car and is complete with an LPG Conversion. Finally come back to BMW after driving an ML55 AMG for the past year.
- Powercat
Re: Facelift Doors
Okay that makes two of us on here with cat D, I did a rough repair on my X you can still see the scars and bruises, which I don't mind as I saved myself a lot of money. good luck with yours, that LPG should help keep running costs down
Re: Facelift Doors
Just put some pictures in the newbies section.
Facelift Doors
no difference in doors!! only front wing bumper n headlights n bonnet different, plus slight difference in rear tail light clusters and soft close boot lid, other than that the same.
- x555
Re: Facelift Doors
[quote=""Neil48is""]Hi,first post and a question already ! I have just bought a lightly damaged 4.8is (needs a wing and a door),could do with knowing if there are any differences between a pre-facelift and a facelift door ?
Many Thanks[/quote]
Hi Neil and welcome along fella
AFAIK the doors are the same but quite a few changes were made to modernise the facelift most noticeably the headlights losing the yellow indicators and of course not forgeting the bhp increase if you drive a smoker not that you do with the king of the road there
Here's a list taken from AW8's brilliant buters guide........
Whats different on a Facelift Car ?
Facelift models were made from 9/03 and for the 2004 Model Year, (MY), onwards.
Exterior :
Revised front end - New headlamps, bumper, grill nostrils, bonnet ,wings.
Minor change to rear lights - A keen eye required to identify if following an E53.
Revised alloys.
Interior - Revised 3 spoke steering wheel on sport models with solid spokes. Also dash saw addition of instrument bezel trims.
Power as follows :
3.0d up from 186HP to 218HP
4.4 up from 286HP to 320HP (with slightly better mpg than outgoing model).
4.6is (347HP) replaced in 5/05 with 360HP 4.8is.
3.0i (only engine size without change to engine for facelift).
Xdrive added : Basically more electronics & abilities when things get tricky.
6 speed auto & manual boxes replaced earlier 5 speed items.
Options : Pano roof became the default sliding glass roof option if desired/purchased.
Many Thanks[/quote]
Exterior :
Revised alloys.
Power as follows :
