Gear box conversion
GT456!
Gear box conversion
Post by GT456! » Mon Jul 27, 2026 7:41 am
The e46 gear box MT can I install this to me e83 which is Automatic?
Gear box conversion
Post by X5Sport » Mon Jul 27, 2026 8:26 am
It’s almost certainly possible, though probably not simple. You’ll need to source a bell-housing with the correct mounting holes, a set of transmission mounts for the box itself, gear-lever, clutch-pedal and mounts, and reprogram the car electronics to ‘identify’ it now has a manual transmission. The E46 box uses a hydraulic clutch action and you’ll need a slave-cylinder. The slave cylinder uses the same brake fluid reservoir as the foot brake.
If there was a manual version of your car sold in the US, getting the kit from a scrap one would at least give you the necessary parts.
Xman
Gear box conversion
Post by Xman » Sun Sep 13, 2026 4:26 pm
It is possible but you will need the correct manual gearbox, clutch, flywheel and pedal setup. Check compatibility with your E83 engine and year first.
