Aircon blowing cold on left but warm on right side vents E70
Post by Leslie » Sat Jul 18, 2026 6:49 pm
The left vents blow cold and the right vents blow at normal air temp which has been warm this last while which is why its become more noticeable although I think it has only started recently.
The most likely cause seems to be a failing heater control valve which sits on the passenger inner wing , there are some very cheap ones on ebay Circ £25 new which I will be avoiding after buying a dud throttle valve last time which didn't work for my dpf issue. Going of genuine ones on ebay it seems the dealer would need 400 quid ! for a plastic valve but Autodoc has a Bosch one for a more palatable 100 delivered.
In other news after getting our ds3 mot yesterday I took a late cancellation and get the x5 mot'ed last night ..Result as otherwise the next date was mid September (waiting times are going back to months here in Northern Ireland again for the umpteenth time ) :headbang: That's 3 of the fleet through mot in 7 days :driving:
Post by Leslie » Sat Aug 01, 2026 3:48 pm
Well I changed the heater control valve on the passenger inner wing , didnt take too long 3 pipes but it doesn't seem much better .lost coolant has been topped up , if i put it to max its certainly hot and min its a little below outside temp while left side is cooling the air but it isn't brilliant either.
Im beginning to think a flap motor isn't moving now but I think that is a can of worms id rather not open. Willcheck codes later.. :headbang:
Its been a bad day found my 205 gti has sheared its alternator tensioner bolt in the pas pump and now ive jammed a torx bit between the inner wing trying to temove the alternator with a ratchet spanner on the torx bit as no clearance so now the ratchet will only go one way and we are stuck :headbang:
Post by Leslie » Sat Aug 01, 2026 7:58 pm
Took the vlave apart nothing looks broken
Post by Leslie » Sat Aug 01, 2026 10:44 pm
Got codes E723 and E729
E723 is no message condensation sensor apparently this lives behind the rearview mirror so I will have a look tomorrow
E729 is no messsage auto air recirc and is the plug on the pollen filters which I left off when I changed the injectors :oops: ,now plugged in and cleared and nothing to do with the current aircon to one side fault.
Post by X5Sport » Sun Aug 02, 2026 9:35 am
Are the solenoids actually good? As in, if you put volts on them does anything happen? The disassembled one has corrosion on the core which might jam it in the bore maybe?
Post by Leslie » Sun Aug 02, 2026 12:05 pm
I've a new one on now so it doesn't really matter , its definitely possible one solenoid has failed but they are free moving ,if would fail open as its spring loaded so heat all the time but I was more getting room temp all the time ,one of the little screw heads has snapped of putting it back together so its faulty now alright lol I unplugged the condensation sensor on the screen ,had cleared codes already but it came back , will clear again now its unplugged .
This is quite expensive to but a genuine one(about £160 ) and I'm not convinced it would only stop aircon to the drivers side so I'm not keen on buying it , I could buy a Chinese copy cheap but we all know how that often goes :rofl:
Trawling the net does not show anyone with the failed condensation sensor having my issues that I can find and the sensor seems a common failure.An ebay seller has sold 450 secondhand ones , if they are really fail that often I wonder how many of the ones they sold are actual duds ,if they are cheap people don't bother to return them :headbang:
