"Auto" jammed in on position on heater/ac unit
The "Auto" button (bottom left of th heater/ac console) got bumped and came off but seems seems to have snapped so cant be put back in place but more importantly the AUTO is permanently on
So ..........
Can the central heater control panel be removed easily and the AUTO switched off - is it likely that I can access the broken part inside to remove it and therefore switch on/off the auto
or am in looking at a whole new unit and if so does anyone have any idea on cost ?
So ..........
Re: "Auto" jammed in on position on heater/ac unit
You may need to sit down!!
http://www.realoem.com/bmw/showparts.do ... g=64&fg=20
It looks like a complete unit, but that's only what Realoem shows. The slide does mention a 'Repair Kit' which could make the shock a lot easier....?
The BMW TIS repair instructions show it as a single module. To get at it you need to remove the heater panel above it with what looks like a credit card type piece of plastic pressed into either side. The back of the switch block is then accessible.
Ebay is probably your friend for this......
There is this on ebay at the moment, don't know if it is the same as yours
http://cgi.ebay.co.uk/BMW-E46-M3-Climat ... 3f0a9b5133
or these
http://shop.ebay.co.uk/i.html?_nkw=BMW+ ... m270.l1313
Phill
or these
Phill
2003 X5 4.6is - Now dead
- B5tew
Hi have a look at this they are easy to replace it just plugs in
http://cgi.ebay.co.uk/BMW-X5-5-HEATER-C ... 3cb8921b9e
Stewart
Stewart
2015 Space grey 30d F15
- pvr
All amazingly cheap really.
911 50th anniversary -
- Black X5
The control unit has the buttons that can be 'popped' out (once they are taken out though, the majoority of times the small plastic lugs snap- meaning they won't stay in afterwards!)
If the button function is permanently on, the small switch is probably jammed - if you have a look in the void left by the missing outer button, you should see a tiny switch at the bottom (IIRC only a coupl of mm wide). May be worth trying to move it a little with a pen etc to try and dislodge it.
Thereplacement button pack from the dealers is VERY expensive for what it is, something close to £70.00- the links above seem very good value for money.
On a long shot, it may be worth contacting user 'Ayat' on here. I bought a single button from him when mine failed a while ago- he may still have the one you are looking for. Drop him a PM.
HTHs.
HTHs.
E70 3.0D SE, Black with Black - Gone but not forgotten! >:D
thanks - but that only shows the control panel above the heater matrix - its the bit with the fan controls the max but the + - arrows for control fan etc etc etc
Anyone know how to get it out ?
- Sanj
I'm confused (I know, not hard) - I can see the Auto button on that eBay link. Is that not what you're after?
The whole unit is just clipped in. Some gentle persuasion with a small flat-head/credit card will help lever it out.
thanks to everyone
- x555
Another one here if it helps..... http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... SS:GB:1123
I'm confused to as the button you mention is on that panel
- kena
My auto button snapped off a while ago. I purchased just the button from someone on ebay who had obviously just dismantled a unit and was selling all the buttons individually. Think I paid about £10 for it. With a little care it just snaps back into place.
- kena
Just did a quick search and this is the only one I could find.
It's in the USA but cheap enough
http://cgi.ebay.co.uk/BMW-E39-E53-5-Ser ... 1c0c0a2a2f
Thanks But snapping a new button into place doesn't switch off the auto as its jammed on due to another piece of the old switch being lodged in there. The button isn't a problem, i can get them fairly easily, its switch the thing off that is the issue
IMO Buy a whole unit off ebay...cheap as chips
The LCD on mine was fecked and a few buttons missing
plug and play
plug and play
