2004 facelift X5 3,0d self levelling
- enver82
The problem is following on my X5 3,0d 2004 facelift the light on the dashboard for the self levelling suspension is on,the car looks perfect and drives perfect but tbe light is on.what to do?where is the problem?
BMW X5 3,0d sport 2004 facelift
Mercedes E-Class 2007 facelift
Kawasaki Z 750 2008
Kawasaki Z 750 2008
Re: 2004 facelift X5 3,0d self levelling
just wonder if its any thing to do with your tyre pressures
regards
regards
- enver82
The tires have the same pressure 2,5bar.Should I change it?
Kawasaki Z 750 2008
Kawasaki Z 750 2008
check the drivers inside door for tyre size and pressure to go with it
also there is the reset button, by the sensors button, but this only happened to me when I got my tyres replaced. self levelling might be another thing ? just a thought
- enver82
I don't know but the yelllow light for the self levelling suspension is on,I also took a look at the sticker on the door and the air pressure in the tires is ok.How to turn the yellow light off?
Kawasaki Z 750 2008
Kawasaki Z 750 2008
This might help? also read that sometimes a battery dissconnect. wait 20 mins and then try,
good luck
good luck
- enver82
Will try with the battery too
Kawasaki Z 750 2008
Kawasaki Z 750 2008
- Contact:
Mine was giving me jip and it ended up being a busted fuse in the rear fuse box.
Dubs
Dubs
- enver82
Where exactly is this fuse?Pls help!!!
Kawasaki Z 750 2008
Kawasaki Z 750 2008
- enver82
The battery thing worked for me
Kawasaki Z 750 2008
Kawasaki Z 750 2008
very pleased, the simple things we often by pass, all sorted gl
- Contact:
PM Replied to, I'll check which fuse tonight after work.
Dubs
Dubs
- wilkoturbo
Where you from I have software that would tell you the problem
bmw x5 le mans blue
- enver82
Mate I'm from Bosnia and Herzegowina
Kawasaki Z 750 2008
Kawasaki Z 750 2008
