Help - Oil Leaking
jeegnesh
Help - Oil Leaking
Post by jeegnesh » Sun Dec 11, 2011 1:54 pm
Last two morning on start the X was making lots of whining sounds that stopped after 2 minutes.
Noticed Oil on the pavement where I was parked, checked the engine bay and the black bottle is caked in oil. What is that bottle and any advice or ideas?
Mods: H Steering, Towbar, Wide Arches, Inforad K2, HIDS, Heated Seats, PS2 Media Center, x555 Sub Box (Focal), Rear Fake Tins, RV Cam, Screen Protect, Front Tints, 168 20's, Re-Map, Black Roundels, De-badge, BSW Dash Mids, Tweeter & Xover, Rear Screens, Intravee
EXPLORER
Re: Help - Oil Leaking
Post by EXPLORER » Sun Dec 11, 2011 3:15 pm
that could be your oil filter housing, any way check if its tight, you ca allways unscrew it, and see, and replace it or if there is a gasket replace also. clean and check again,
x5dom
Post by x5dom » Sun Dec 11, 2011 3:19 pm
As above reply. That's your oil filter housing. Have you checked it's tightened up enough? Should have the correct Nm torque stamped on the cap there. There should be a rubber O-ring that sits behind the cap's thread, perhaps that has failed causing leakage. Either way, unscrew it when motor has cooled a little and check this rubber ring... give it all a good clean... and replace at the right tightness. Then keep an eye on it. Might just need a replacement O-ring
Might be an idea to check your dipstick oil level too in case this has been going on for a while.
_________________________________________________________________________________________________
2005/55 E53 3.0d Sport - Sterling Grey/Dakota Black - Sports Plus Pack - 168 20s - Comms Pack - and many toys!  :)
Toy: '95 VW Corrado VR6
IanP
Post by IanP » Sun Dec 11, 2011 4:02 pm
Haved you got the correct oil in? The whining could be the oil pump cavitating as the oil is a bit too viscous when it is cold. The noise might go away as the oil warms up. The cold oil might have overpressured the oil filter housing as well.
jeegnesh
Help - Oil Leaking
Post by jeegnesh » Sun Dec 11, 2011 4:14 pm
Oil is just above min. I am also sure this has happened over past 2 days, as my driveway has no oil but was parked elsewhere for last 2 nights and oil marks are there.
Don't have anything that's going to tell me regards right torque when righted back :-(
Oil is 5w-30 fully synth Comma Super-Z been in there since last service done 15k and 2 green lights to go yet.
Do u need special spanner as the housing has that huge black plastic nut head?
EXPLORER
Post by EXPLORER » Sun Dec 11, 2011 6:01 pm
socket should fit, or ring
jeegnesh
Help - Oil Leaking
Post by jeegnesh » Mon Dec 12, 2011 2:31 pm
Went to a man with a torque wrench. It says 25Nm was about less then a quarter turn short. Cleaned up the housing ran it for a bit there and no leak.
185 miles later:
So will change the O ring tomorrow. Still doesn't explain why so much came out the first time round.
Bargain Bucket
Post by Bargain Bucket » Mon Dec 12, 2011 2:48 pm
If the o-ring doesn't solve it then you have a massive oil presure issue :(
BMW X5 3.0d M-Sport facelift (E53).
jeegnesh
Post by jeegnesh » Mon Dec 12, 2011 3:00 pm
[quote=""Bargain Bucket""]If the o-ring doesn't solve it then you have a massive oil presure issue :([/quote]
i'll keep my fingers crossed then :roll:
jason@bwchiptune
Contact:
Help - Oil Leaking
Post by jason@bwchiptune » Mon Dec 12, 2011 11:32 pm
Comma oil
I'm sure I read so where years ago that it was recycled used old oil
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
jeegnesh
Help - Oil Leaking
Post by jeegnesh » Tue Dec 13, 2011 10:33 am
[quote=""jason@bwchiptune""]Comma oil
I'm sure I read so where years ago that it was recycled used old oil[/quote]
great I'm closing in on a change I'll make sure I don't use it again.
jeegnesh
Help - Oil Leaking
Post by jeegnesh » Tue Dec 13, 2011 4:57 pm
New seal on, old one was not cracked but seemed thinner and very hard.
shadrack
Post by shadrack » Tue Dec 13, 2011 6:06 pm
i used this in my old x5 3.0i and it never used a drop of oil, did oil change put that in (motor factors recomended) and it started using 1ltr every 800-1000miles!!! would never use it again
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
Bargain Bucket
Post by Bargain Bucket » Tue Dec 13, 2011 8:17 pm
[quote=""jeegnesh""]New seal on, old one was not cracked but seemed thinner and very hard.[/quote]
Fingers crossed for you. Sounds like maybe it hasn't been changed in a looooong time.
Sanj
Post by Sanj » Tue Dec 13, 2011 8:37 pm
[quote=""jeegnesh""]seemed thinner and very hard.[/quote]
Was he talking about the seal!!!! :oops:
:rofl:
