BMW x5 ecu unlocking or dead ecu's
- jason@bwchiptune
- Contact:
BMW engine ECU's are locked to the car they have been programmed to so you can't just reuse a second hand ecu from one car to another
we have been programming and unlocking these used ECU's for many years now,this means if your ECU has problems or is dead you don't have to buy a new one from a dealer which costs up to £1000-£1600
or you think it's the ECU which is faulty but not sure with out trying another we can make a test ecu
some of the problems you may have
your DME or DDE engine ecu is dead,
your X5 dose not start,
you have no comms to your ECU,
the ECU pins are corroded away
your ECU has the wrong software flashed to it (it dose happen)
had you ECU flashed, you or they killed your ECU flashing the ECU,
burnt out ecu
Water in the ecu
we have a way to repair them as well
we can unlock,repair your ECU,or provide you with a ECU
we can unlock and even put back to a virgin state(the same as if you of brought a new ECU from the dealers) so a main dealer or a BMW independent can then reparogram the second hand ECU to your car
we keep ECU's in stock
X5 ECU's
petrols
3.0i DME ms43
4.4i ms7.2
4.4i me9
4.6i me9
4.8i me9
diesels
3.0d DDE 4 edc15
3.0d DDE 5 edc16
some edc17
We can now remove Dpf(diesel particular fitter) from the ecu' software
For engine conversions we can customise the ecu to fit the new shell
ie if you are using a m3 or v8 engine in a e30 shell you will have problems with the engine ecu looking for info from other moduals which are not there causing the engine not to rev to full rpm range and holding back
burnt out ecu
Water in the ecu
X5 ECU's
petrols
3.0i DME ms43
4.4i ms7.2
4.4i me9
4.6i me9
4.8i me9
diesels
3.0d DDE 4 edc15
3.0d DDE 5 edc16
some edc17
Last edited by jason@bwchiptune on Wed Nov 16, 2011 10:49 pm, edited 1 time in total.
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
02085611818
- jason@bwchiptune
- Contact:
We can now offer replacement ecu's for most of the BMW and Mini range
02085611818
02085611818
Re: BMW x5 ecu unlocking or dead ecu's
Where is the location of the ECU on a 2001 BMW X5 4.4i?
- jason@bwchiptune
- Contact:
In the e box which in under the bonnet under the windscreen near side of the car
You will need to remove the main plastic cover in the center in front on the windscreen that sits around the pollen filter
Remove the near side pollen vent
You will then see a big black box on the nearside
Remove the cover and the engine Ecu will have DME on it
It is held in by 2 plastic clips which you you need to push away from Ecu as you lift the Ecu up to remove
02085611818
02085611818
Hi Jason my DME on my 2001 4.4 X5 has a problem it keeps showing the throttle is jammed even though it's been replaced with a genuine new throttle body. I've been told the DME unit maybe at fault, how much would it cost to test and if possible fix the unit?
- jason@bwchiptune
- Contact:
[quote=""swipe""]Hi Jason my DME on my 2001 4.4 X5 has a problem it keeps showing the throttle is jammed even though it's been replaced with a genuine new throttle body. I've been told the DME unit maybe at fault, how much would it cost to test and if possible fix the unit?[/quote]
To test a new Ecu on your car to see if this fixes your problems will cost 150
If you then wanted the Ecu it would depend which Ecu is fitted to your car
A replacement Ecu will cost between 375-500ish in total to pay
If it is not the Ecu then it would the 150 to try a new Ecu on your car
02085611818
02085611818
[quote=""jason@bwchiptune""]
If it is not the Ecu then it would the 150 to try a new Ecu on your car[/quote]
Jason would you need my DME unit sent to you? my DME unit number is 7 508698 if this helps.
- jason@bwchiptune
- Contact:
[quote=""swipe""][quote=""jason@bwchiptune""]
Jason would you need my DME unit sent to you? my DME unit number is 7 508698 if this helps.[/quote]
i would normally need the car as well
just checked and yours is the same hardware as mine 4.4i x5
so if you cant get down send the ecu and the new throttle body as well as the old one i will test on my car and let you know what i find
when you send me your ecu can you write your reg on the ecu and list the problems you have and full name and address
i have some ecus here that have been sent to me to test with no or wrong customers details so i cant get in touch with them
if you out there please give me a ring as your car must be missing its ecu
i get a good few ecu's sent to me every week
so the owners of the
4.4i range rover ecu
e39 523i ecu,e38 728i
vw golf 1.9tdi
mini 1.6 cooper ecu
please get in contact with us
vw golf 1.9tdi
mini 1.6 cooper ecu
02085611818
02085611818
- Rusty
Can't believe people don't bother following up after send an ecu for repair, that's just crazy
Runabout - E92 3 Series Coupe
- jason@bwchiptune
- Contact:
May be they forget or lost our details
Have some from over the water and we have payed the duty on them but when we open the package there no contact details
Have one from Ireland but can't read there writing I've tried all the numbers it looks like but still can't get hold of them
02085611818
02085611818
Jason if you're about on the 6th I can drive over to you with the parts, I won't be able to drive the car X5 over as it's a pig at the mo. Then we can have a chat about the problems on my 4.4.
- jason@bwchiptune
- Contact:
[quote=""swipe""]Jason if you're about on the 6th I can drive over to you with the parts, I won't be able to drive the car X5 over as it's a pig at the mo. Then we can have a chat about the problems on my 4.4.[/quote]
Yer no problem you may have to leave the parts with me so I can test them
If you coming over you might as well bring a the key and ews box as well
If you can text me on 07831103030 just to confirm the time
02085611818
02085611818
Where is the EWS unit is it easy to remove? I'll be able to get the parts on tuesday or wednesday, I 'll try and get to you for around 1pm on friday.
- jason@bwchiptune
- Contact:
[quote=""swipe""]Where is the EWS unit is it easy to remove? I'll be able to get the parts on tuesday or wednesday, I 'll try and get to you for around 1pm on friday.[/quote]
Ews is on the drivers side of dash
White box size of a cigaret packet has ews on it
02085611818
02085611818
Hi jason just to let you know that the ecu and throttle body worked straight away once plugged back in with no error codes. The X5 has still stalled only once though been digging around on the net about a service update and found out the rpm may have to be raised 100 rpm to stop the stalling. Apparently it's when there is a load caused by the steering not sure if you've ever heard of this before, just wondered what your thoughts were? Also will be looking to get my Mercedes E320 CDI Chipped at some stage soon. Thanks for looking into the ecu fault for me "Top Man".
