Can anyobody decipher this?
It details Removing and installing/replacing grill bumper trim, the two top chequer bits
http://tis.spaghetticoder.org/s/view.pl?1/09/13/68
It seems tos suggest some sliding unpicking movement that I can't get my head around. Is this possoble to remove without removing the front bumper?
On Real OEM the two parts are shown here as part 9
Even crazier is that silver $72.68 is double the price of black $35.21.....how much does a tin of paint cost!!!
http://www.realoem.com/bmw/showparts.do ... g=51&fg=15
Facelift Front Bumper Upper Grills
storminmike
Raj
Re: Facelift Front Bumper Upper Grills
I've replaced all mine as all were damaged. Bumper off as you have to slide them across to release them.
storminmike
[quote=""Raj""]I've replaced all mine as all were damaged. Bumper off as you have to slide them across to release them.[/quote]
Thought as much....Is the "slide" obvious?
Still ludicrous the price hike between matt black and off silver
Are they beyond repair, or could you spray them?
storminmike
[quote=""X5Sport""]Are they beyond repair, or could you spray them?[/quote]
actually...it's not my X5 but another one I know of
Not sure how but they are both toast and only really worth of replacement. They're titanium which in that space is not exactly on show. Given the massive price difference then black ones with titan silver paint (or that darker rover colour mentioned before on knobs and steering wheel replacement threads) would seem a worthy shout. Not sure of the longevity of paint though
It was more about how much hassle it is to get them out....they look chunky, chunkier than I first realised
dirtymonkey29
I need a drivers side upper after a big stone knocked a hole in it. Mine are same colour as the car (sterling grey)
I don't know if they have been sprayed but looks like they only come in black and Titan silver
Raj
[quote=""storminmike""][quote=""Raj""]I've replaced all mine as all were damaged. Bumper off as you have to slide them across to release them.[/quote]
Still ludicrous the price hike between matt black and off silver[/quote]
Once the bumper is off (very straight forward mind) you will see how they are held on.
storminmike
[quote=""Raj""][quote=""storminmike""][quote=""Raj""]I've replaced all mine as all were damaged. Bumper off as you have to slide them across to release them.[/quote]
Once the bumper is off (very straight forward mind) you will see how they are held on.[/quote]
Thanks for that Raj
edit....actually
You can see...touch them without taking the bumper off with the bonnet off
still can't figure how they come out
Thanks for that Raj
edit....actually
