Testing and Diagnosing the E53 Webasto Thermo Top C/Z
- jaynana
Re: Testing and Diagnosing the E53 Webasto Thermo Top C/Z
switching on from the nav screen and switching on from the remote shoudl be exactly the same. input to webo is the same - +12v to pin1/remote.
except just one thing - the remote has a 'latching' capability to keep the pin1/remote powered for whatever duration (30mins in this case).
u can test ur remote kit to see if it does this, a simple volt meter check should do.
2 ft thing - that's a bummer! supposed to work 60m??
j
j
- malc1950
Hi Jaynana can you please explain how to test the remote, i do have a volt meter
Speed camera warning, Heated front seats, Wabasto heater, Auto wipers lights, Rear view camera.
- jaynana
here's what i'd do:
1. check that pin 1 of below gets +12v with the volt meter (i'm sure it does, if not fuse 86 is to the first culprit)
2. do the above test connection to isolate the issue (either webo or the remote):
basically pin 3 gets powered +12v from pin 1. pin 1 is power, pin 3 is remote start signal to webo.
you say if you enable the webo from the satnav screen the webo runs for half hr? in which case if you do this it should run as well (ensure u DONT DISCON IN LESS THAN 3 MIN - not good).
if that does not run the webo there's some issue with the webo or the wiring or something else.
if that makes the webo work u have an issue with the remote. if this is the case u have to check the remote:
here's how i'd test the remote:
- disconnect the remote receiver
- provide power to it (pin 1 is +12v; last pin (6?) is ground).
- connect the volt meter to pins 3 and 6(?) (pin 3 is remote start of webo)
- press the remote!
u should be able to see power on pins 3 & 6(?) on your volt meter, and that should stay constant for the 30 mins.
if not, the remote is faulty or not configured properly.
- press the remote!
OK that's mine fitted and working perfect.
The OEM plug in the boot doesn't fit straight into the Carsystems T91, it's the wrong shape.
A loom is supplied that plugs into the T91 and has bare wires on the other end (6 of them but only 3 are needed - Red, Black, Green). Simply cut of the OEM BMW plug and solder/heat shrink them (pull fuse 86 first).
Route the aerial upto the rear window and your done !
When you press On the red light illuminates, then it flashes every couple of seconds while it's running to confirm its On, it's pre programmed to run for 30mins but can be changed in incrimates of 10mins and can be stopped with the Off button at any time.
Range is supposed to be 1000Metres, I haven't tested it that far yet but will try later when I take the dog out !
- jaynana
excellent outcome! well done!
[quote="mikem"]
Any pictures Mike or is it completely obvious once you get in there.
05 Mercedes SL350
05 Mercedes SL350
I'm not great with pics Denis but they would've been identical to Jaynana's. The connector your looking for is taped to the 40pin quad lock for the radio tuner and there's some plastic clips there to hold the module in place (it's not a tight fit but the extra wiring of the new loom will pad it out) there's already loads of cable running from the battery across to the drivers side rear window area, so follow that, then up behind the lights to the glass area for the aerial. There are 2 screws holding the Plastic trim in place on the C pillar, 1 is visible the other is behind the little cover around the latch for the rear tailgate (this little cover pulls off and you'll see the screw) this should give you enough flex to squeeze the aerial and cable through without fully removing the panel as its clipped to the headlining.
I don't doubt the 1000M range in clean air, it's worked this morning inside a building about 4-500M away with other buildings between us.
- malc1950
Hi Jaynana thanks for sending me the information i require to test my t91, i will let you know the outcome when i have checked it at the weekend ,
[quote="jaynana"]
I have sent it to a contact i found in Germany, who has a full BMW webasto test harness and claims to repair these units (can't really remember how i found him..) its not really a risk cos i've got mine working with a spare unit.
Hi I have a Range Rover with a similar problem - think it may be the ECU. How did you get on with the ECU repair? Who did you send it to?
- jaynana
i've sent my pcb (he calls it the cpu) to this.
he's fixed the unit, i've paid £90 for it incl a new glow plug + shipment, he's posted it back; however, as per the DHL tracking number its still on its way back!
if all goes well i will get it by this weekend and i'll fix it in the webo and test it in the car this weekend.
planning to do a post once i have a confirmation on the success/failure of this service.
j
ps
not too great with english, google translator to the rescue
j
ps
- CondorX5
My 4.8is has a Webasto, its brilliant in the winter. Shudder to think what BMW would do if it ever had to be replaced as the main dealers are that good that they told me that even my Comms Pack was non-oem, remember........and that they had decided the tv tuner was analogue.......... Ages ago they told me the Webasto could not be fitted on a petrol car so I showed them where it was, both on the car and on the printout of my Xes options........their eyes were out on stalks! Mine is slightly different to the diesel version as it says "benzin" on the side and presumably runs on petrol. It was a pricey option from memory, around £1000, very few around in the UK and most dealers pretend they never existed.
One of the guys on Landyzone actually fitted a webasto to his P38 petrol Rangey - it was a diesel webasto that he managed to buy from a scrappy out of a Rover 75, he concocted some sort of tiny diesel tank to fuel it, and as I remember it worked very well - so Turks, there is hope yet, I am sure it can be done!
There is a parking heater specialist on the VW T4 forum - he is very helpful and knowledgeable. I discovered our ancient (but venerable) Caravelle has an aux heater as its one of the higher spec models for its time (2001) but its an Eberspacher so quite complicated and expensive to get it working as a parking heater as well - this guy has been very helpful with looking into converting it and he does repairs and installations of Webastos mainly, so worth a shout if you are stuck.
X5 2005 Le Mans Blue 4.8is
- jaynana
[quote="CondorX5"]
Ages ago they told me the Webasto could not be fitted on a petrol car so I showed them where it was, both on the car and on the printout of my Xes options........their eyes were out on stalks![/quote]
[quote="CondorX5"]
interesting.. can you send a link pls..
thx
j
[quote="CondorX5"]
thx
j
- jaynana
[quote="jaynana"]
j
ps
i've received the package as below - my PCB tested and working, new glow plug:
fixed into my original and serviced webo (serviced as per original post on this thread), fixed into the car, ALL WORKING FINE!
so that's my own webo repaired.
which means:
- i can confirm a webo pcb test/repair service for BMWs
- i now have a spare working webo, bought from an online breaker, still with about a month of warranty left.. which i can sell or attempt to return.
said that, CondorX5, still keen to know the parking heater specialist on the VW T4 forum if u or somebody can send me a link pls.. few things worth discussing
j
ps
which means:
- wilkoturbo
Wow this is great news !!! How much for the working WebO???
bmw x5 le mans blue
- CondorX5
Sorry, was away from ipad and iPhone today
for a few hours...........
Heres a link to his profile on the vwT4 forum. We have an ancient Caravelle, so am a member on there, it is a great resource for the T4 and T5 vans. Not many BMWs or indeed any other marques can boast the starship mileages these old vans run up, ours is close to 300K miles! This guy really knows his stuff with these heaters and does installations and repairs full time.
http://www.vwt4forum.co.uk/member.php?u=40481
