25w Cree LED Angel Eye Units
X5LeMans
Re: 25w Cree LED Angel Eye Units
Post by X5LeMans » Sun Jan 27, 2013 1:18 am
I gather the 25W is a bit of "Marketing" speak. They are apparently 12.5W each. I was thinking I should change the yellow bulbs in my Angel Eyes, but undecided which kit to get  :)
Raj
Post by Raj » Sun Jan 27, 2013 10:55 am
[quote="X5LeMans"]
Tbh probably just go with whatever is cost effective as they are pretty much all of a similar brightness.
dark_stranger
Post by dark_stranger » Sun Jan 27, 2013 6:42 pm
[quote="X5LeMans"]
Some sellers claim that there 25w's are 12.5w per unit, where as others, claim theirs are 25w per unit. I only paid £40 for these, but most sellers are selling these £60'ish.
X5LeMans
Post by X5LeMans » Sun Jan 27, 2013 6:53 pm
Big question is are you impressed by them, even if they are 12.5watt each side  that's still 25% more power (and hopefully more brightness) than a 10w led kit :) And probably a fair bit nicer looking than the standard yellow look!.
Post by X5Sport » Sun Jan 27, 2013 7:15 pm
Time for a bit of maths & physics....no I won't I'll just tell you the answer.
To double the number of lumens of a light source you need to quadruple the output level of that source.  That does not mean adding more lamps because they are the same 'apparent brightness' it means quadrupling each source.
Think about a 40W std lightbulb and then a 100W bulb...more than twice the power, but not double the light output.  Doubling the light power actually gives you the square root of 2 in terms of an increase, 1.414 times.  To double it you need the square root of 4 - hence 4 times the light power needed.  Sorry, that was a maths bit.. :-[
X5LeMans
Post by X5LeMans » Mon Jan 28, 2013 2:14 am
Richard..
Yeah.. That's like audio systems then, it generally takes a 10x increase in watts, to double the loudness (all things being equal.. which with audio it usually isn't.
I'm guessing the formula behind audio loudness isn't a gazillion miles away from the same as light lumens V watts, when comparing comparable technologies.
IE cant compare incandescent with LED directly, and then I guess the colour temperature also affects the perceived brightness as well.
Graham
mikem
Post by mikem » Mon Jan 28, 2013 7:47 am
They look the same as my 5W hids4u.
Raj
Post by Raj » Mon Jan 28, 2013 8:15 am
Nice one Richard...... :blink:
