my OBD flickers on and off sometimes
then comes back on later or a day later
any ideas
Thanks Jack
OBD goes of and flickers on and off
- bemdblu
Re: OBD goes of and flickers on and off
Hi Jack , mine does the same from time to time , i also get a crackling in the speakers some times , i asked on here and was told it could be a bad connection in the ribbon cable in the head unit , or a module in the boot , where do ya start ... mine hasnt done it for a few weeks now so i left it alone , you can check back on some older threads for the same problems and get some more fix info , good luck . Colin ...
05 , 30d Le Mans Blue Sport
- Steamyrotter
depends which one it is??
Need Car model & Year and if SAT Nav or not to be able to give a more robust answer
Please note...
Please note...
