Parking heater remote start- Enabling
Re: Parking heater remote start- Enabling
BL02WAS , yep thats what i'm saying....
X5 3.0D Custom black carbon fibre edition
That's great, nice 1!!! Will let you know how I fare in the morning!!! Cheers!!!
- ChewingBacca
Also you must ensure you use the "NO" terminal and not the "NC" terminal.
See the diagram on page 2 of this thread.
Hi scanner arrived today, can anyne give me a quick guide on how to change settings such as aux heating and indicators flash when locked etc, dont want to wreck anything lol
thanks
thanks
2001 X5 3.0d sport
Mcc thanks, I thought n.o was the way to wire it other wise it would be latched permanently when off?? I.e normally open would be open circuit when no power to it which is what we want... Not normally closed???
Yep N.O is then connected to the heater 12v input.
Does anone know what the cold and hot check is in the light coding?
Many thanks
Many thanks
2001 X5 3.0d sport
Nc not no
- ChewingBacca
BLO See diagram on page 2.
mcc See PM.
gareth
Hot check is circuit continuity when the bulb are on looking for non working bulbs.
Cold is when the key is turned and before the light are on. A low current is pulsed through the lighting circuit.
The latter is why my LED side markers (lower resistance than filament bulbs) pulse ten times when I turn the key. I should disable cold checking.
mcc See PM.
gareth
Hi thanks for the reply, my LED markers and rear number plate LED's strobe when ingition is turned on so then this is the cold check which needs disabled. Is the strobing every 30 secs when lights are off the hot check or is that still the cold check?
I have worked out to enable beep and flashing on locking/ unlocking and enable HEAT ON (I have the old MID not monior, doing this you lose the stopwatch functions), if timer is set does it default at heat on or vent on?
How do I disable cold check with BMW scanner 1.4.0
Cant wait to check out if heater works (will install relay and remote if working)
Many many thanks
Many many thanks
2001 X5 3.0d sport
BL02WAS, live from the power feed to common on the relay.
N.O on the relay to the heater pin 1.
Hope that helps.
Hope that helps.
Come on BLO2WAS sort it out
after all my expert advise and you are still dragging your heels
BTW i hope you aren't involved in any wiring/electrics down where you work
or they may have to send you back to Texas on another course
[quote=""Sanj""]Someone mentioned a good battery - I had that problem. Battery changed all was fine...[/quote]
i'd tried mine in the past and nothing, but i too think the battery was on its way out, just had a new one fitted along with new fuel pumps back and front (don't ask) so now the cold weather is here im hoping i can get this thing to work.......
[quote=""ChewingBacca""]Also you must ensure you use the "NO" terminal and not the "NC" terminal.
See the diagram on page 2 of this thread.[/quote]
This has been edited! Lol it was the other way around and thus the conflicting advice lol. I am not any more Mitch!! Used to be tho haa!!! But thing is I thought that power supplied the board etc so easy mistake!! Lol!!
- ChewingBacca
You got me LOL.
I rushed in.
But the diagram has never changed.
