Couple of niggles, advise needed please...
Bigrichw
Hi guys..
Just took delivery of a 54 plate 3.0d Sport - on the whole I am very happy with it - but like any car you buy 2nd hand there are always a couple of minor issues you need to address, I wonder if anyone can help..
1: When the FM radio is on there is an annoying background buzz/whirring noise??
2: The wing mirrors are retractable, but the passenger one doesn't move, and the drivers side retracts and pops straight back out again
3: The pressure in the windscreen washer jets is very poor (headlight ones fine)
4: Rear wiper is ill fitting, and leaves a big gap (the ends touch the glass, but the middle doesnt)
Also, I am considering a remap, but I have heard there is some parts that cause issues with this engine and its advisable to remove them?
Rich
Rich
Bigrichw
Re: Couple of niggles, advise needed please...
Also heated rear screen doesn't work, maybe the fuse - where can I find this please?
[quote="Bigrichw"]
Hi guys..
Rich
1. Faulty suppressor or bad aerial cable.
2. Have a trawl on here as this is a known issue and there are DIY fixes.
3. Probably a blocked filter on the washer tank. These cars are very sensitive to which washer fluid is used as some can cause a jelly like gunk to grow in the tank.
4. If you are referring to 'swirl flaps', the E53 Diesel engine does not have them despite what some people will tell you. We've checked and no one has found any flaps or control gear fitted to the 3.0D.
EDIT: rear screen could be the cause of your radio issue. Fuse is in the right side boot cubby from memory.
Hi guys..
Rich
Bigrichw
Thats great, thank you for your advise.
Is there anything you can flush through the system to un-gunk the pipes etc?
Bigrichw
You are very helpful, thank you. I just ran a DIS on it... All ok, other than the attached
Does this need attention?
- shadrack
probably not clear codes run it then check them again and see if they have returned, richard has answer most of your queries anyway all easy diy fixes
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
Bigrichw
I did clear them down, and ran again, they won't disappear - but sometimes says fault not present, then fault present. Engine is starting fine, no lumpy tick over, or anything... confused...
- shadrack
i wouldnt worry about a glow plug fault
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
Bigrichw
Ok, doke - I shall do just that - thanks mate.
Best get the washers, and heated rear screen fixed - weekend jobs
- shadrack
might be wrong but mine used to throw this code pretty often with no side effects at all in 2 years and 40k miles, just imagine your one of the 99% of owners that dont have a fault code reader, no dash lights, no side effects, no worries!
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
- amacman
The VTG 54C6 .
I think that means the transfer case fluid should be replaced and the values thereafter reset . check with dealer or specialist as it`s not an expensive job .
Bigrichw
Yeah I see what you are saying. It runs fine so I guess nothing really to worry about.
Not having a heated rear screen and virtually no windscreen washers is a pain though especially at this time of year.
- amacman
Takes 15 minutes or less to sort the washers
Drain reservoir by siphoning if you know how to do that safely or else just lift out the pumps and let it drain . It may not drain until you remove the rubber seals which the pumps insert into , these have screen filters which are most likely blocked. The seals are easy to remove .
Clean the filters and flush the reservoir . The reservoir is easy to remove if you want . One or Two nuts secure it .
Bigrichw
Yeah, ill get it done... Any ideas about the heated rear screen? Assuming the fuse is OK, what else could it be? Cheers
