[quote="martin33100"]
Do you guys have adaptive drive?, just wondered if the suspension was set softer and the camber was also different on these cars.
Nope on adaptive drive too
Dukester
E70 wheel alignment
Re: E70 wheel alignment
2016 X5 40D M Sport in Black
Used to Drive 2012 X5 40D M Sport in White
Used to Drive 2010 X5 3.5D M Sport in Black
Used to Drive 2008 X5 30sd M Sport in Space Grey
[quote="POC"]
The wear on the inside of the tyres is pretty much 'standard' form due to the way BMW set the geometry up on the X5s I'm afraid.
They need to camber to make the big ol' trucks handle!
This is not quite true...
I learned a valuable lesson on my first X5 (E53 - with 20's) about how the BMW default settings can ruin the inner edge of the rear tyres, and can lead to wear on the outer edge of the fronts - especially if they set your car to the wrong extreme of their range of adjustment.
Even though mine was a BMW Approved Used car I noticed I had excessive wear on the inner edges of the rears after a few thousand miles. Fortunately I caught it early enough.
I use http://www.wheels-inmotion.co.uk/ in Chesham for all of my cars - they are very knowledgable, and spend the time to discuss what you want to achieve.
They found that my E53 was set within BMW tolerances, but it was clear that this was still causing uneven wear. They reset my car within BMW tolerances, but at the other limit such there was less camber and therefore even wear. I was also able to swap the rear tyres left to right (directional tyres, so this involved taking the wheels off the rims).
It can be done, and it definitely did not affect the handling.
Likewise with my current X5M, as soon as I could I got it looked at by WIM. Once again it was within BMW tolerances and it was clear just by looking at the camber and the wear pattern on the tyres that I was going to waste a set of tyres.
This time I got Wheels in Motion to make an adjustment just outside of the BMW range in order to further preserve my tyres without compromisisng my handling. They are able to adjust a number of parameters (although not the front camber) in order to achieve a decent overall balance.
I was careful to give the car a decent spirited test drive before and after, and once again I can categorically state that the handling was unaffected.
Rather frustratingly a defective driveshaft had to be replaced by BMW immediately after this, and BMW perfromed a KDS on the car. I had to go back to WIM to have it checked and adjusted. Interestingly BWM had reset it to an even more agressive rear camber (I have decent before and after measurements to compare)!
BMW service tend not to give you input into their KDS process, and I'm not sure as to how diligent they are when they set up the car - WIM are fastidious in achieving accurate settings, whereas the numbers that were measured post KDS where a little out of kilter. Probably not enough to be noticeable, but nevertheless indiciative of the care taken in setting up the car.
It confuses me as to why BMW do this - they don't necessarily benefit from replacing the tyres, and it can't be great in terms of customer satisfaction when your car chews through a set of tyres. Moreover, how many X5 owners drive their cars to the point where those extra few degrees of camber make a difference to the handling?
With the cost of these tyres it's well worth spending the money to get the car set up properly. But beware - not all tyre centres have the equipment or expertise to do this well.
Regarding the alignment, as far as I know you can only adjust the front toe? and the front camber can be adjusted if you buy the camber adjustment upper arms from BMW.
Regarding the rear is it also only the toe that can be adjusted? or can the rear camber be as well?
Correct - front toe only, unless you change suspension components.
Rear camber adjustable.
Speedy-un.
Ive had exactly the same "treatment" at BMW. And came away, somewhat frustrated...And £150 out of pocket...
I now need to find a good local indie wheel alignment place. [Blackpool / Preston area]....Who knows there stuff....
Dave W.
BMW E70 X5 40D
BMW E70 X5 40D
