How-To articles ONLY go here.
Timh
Post by Timh » Sun Nov 21, 2010 3:56 pm
Got my scanner yesterday!!!!.....yipee.
Enabled tv in motion
Enabled aux heater function on computer
Enabled audio beep on locking/unlocking
What else can I do lol.... Need to have more of a look into it when I get time.
Good piece of kit though
Tim
Anyone in the glasgow area wanting their aux heating enabled then give me a shout.
gareth82
Post by gareth82 » Sun Nov 21, 2010 4:52 pm
[quote=""Timh""]Got my scanner yesterday!!!!.....yipee.
Tim
Anyone in the glasgow area wanting their aux heating enabled then give me a shout.[/quote]
HI did you buy the scanner from the attached lin if so did delivery take long?
2001 X5 3.0d sport
t400
Post by t400 » Sun Nov 21, 2010 6:06 pm
[quote=""mcc05""]t400, well that is strange, again have you tried putting 12v to pin one of the heater directly.
All alternatively set the timer and see if when it is on that the heater is getting a 12v signal to pin 1.[/quote]
how do i apply the 12v to pin one?
Im not much of an electrician - but i'll give it ago with some instructions
I used a scanguage to see the battery at it was on about 12.2volts average with the ignition off... thats enough isnt it? : :?
Timh
Post by Timh » Sun Nov 21, 2010 6:40 pm
Put wire from the 12v jump start connector to the white/green wire on the Webasto unit.
Any 12v would be ok. If you look at begining of this post you will see the jump start point.
Hope this helps
Tim
Timh
Post by Timh » Sun Nov 21, 2010 6:43 pm
Yes I bought one from eBay as per the link. Delivery just over a week so not rapid!
Really pleased with it though... Did my neighbours x5 aux heater as well!!
Easy to use
Tim
t400
Post by t400 » Sun Nov 21, 2010 9:30 pm
[quote=""Timh""]Put wire from the 12v jump start connector to the white/green wire on the Webasto unit.
Hope this helps
Tim[/quote]
Reet, applied 12v to pin one and the unit seemed to start ( little whirring noise)
It ran for about 2-3 minutes and then shut down
Is that the norm?
fenj66
Post by fenj66 » Mon Nov 22, 2010 8:45 am
t400-- did you maintain the +12v continuously?
fenj66
Post by fenj66 » Mon Nov 22, 2010 8:50 am
sorry if this has been mentioned earlier but to all having trouble getting their heater to work; are you remembering that the outside temp needs to be +5C or less AND plenty of fuel in the tank AND a good condition battery are all necessary for the unit to work.
t400
Post by t400 » Mon Nov 22, 2010 9:39 am
[quote=""fenj66""]t400-- did you maintain the +12v continuously?[/quote]
I applied the 12v for about 5 seconds......
fuel - full
battery 12.2v with ignition off
outside temp 7 degrees
mcc05
Post by mcc05 » Mon Nov 22, 2010 9:47 am
t400, leave the 12v applied for much longer, mine kicks up make a bit of noise for a minute or so, then kicks in the heater and starts to burn fuel.
If yours is working it should do the same, if it stops with the 12v applied you have a problem.
X5 3.0D Custom black carbon fibre edition
x555
Post by x555 » Mon Nov 22, 2010 6:08 pm
The tremperature and fuel won't facter when aplying 12v to pin 1 (i think it does if using oem set up as fenj66 said) but if you are testing it straight on to pin 1/white green wire on the webasto with 12v it will run constant untill you take it off,
Obviously you will need some fuel but the main factor is the battery.....i remember Sanj having loads of hassle when doing his but when i did mine (diy style)after Sanj had helped me with the wiring etc ;) it worked straight away and will work in any temp or whatever fuel but you have to remember to turn it off or it will keep running unlike the oem set up.
Basicly if you put 12v to the green/white wire on the webasto it should run untill you take it off unless the battrey is low.
Sanj
Post by Sanj » Mon Nov 22, 2010 6:59 pm
Someone mentioned a good battery - I had that problem. Battery changed all was fine...
BL02WAS
Post by BL02WAS » Tue Nov 23, 2010 5:13 pm
Hi all, just installed my remote rf channel switcher box. Box powered up and programmed ok, took pos off jump start terminal and Neg off the neg jump start etc, as it's a switch I presume it's non polar which seems to be case as I have powered it fine. Only problem is when I activate a relay via switch, I get no power out from the relay??? Tried both relays with meter on volts dc auto range and nothing??? See's the 12 volts into the remote box and nothing on outlets of relays when engaged via remote switch??? The led's light up to say relay has engaged and I can hear them clicking in but no voltage out??? I don't have led installed at mo, just the power straight out to pin 1 of webasto, I've tried disconnecting all power outs and trying it just on terminal blocks but nothing??? Shall I try reversing polarity of input power terminals??? I'm stuck here???
mcc05
Post by mcc05 » Tue Nov 23, 2010 5:27 pm
BL02WAS, I hope i'm not telling you how to suck eggs, but i assume you have linked the COMMON on the relay from the 12v supply, so that when it switches it will provide the feed?
The dashes line in the diagram http://xdrivers.co.uk/forum/viewtopic.p ... t=15#p5955 from supply to relay.
BL02WAS
Post by BL02WAS » Tue Nov 23, 2010 6:07 pm
Mcc, hi, right, I presumed that providing power to the unit gave the relays their power!!! Are you saying to put a link from my power in across to the common on the relay connectors??? If so shall try this in the morning and should hopefully solve this!!! Thanks!!! Let me know
