Coolant pump
- henrym3
Coolant pump
Leslie, I had that heater problem with one side, it was the heater valve
- henrym3
Coolant pump
I started this thread by whining about getting a seal for my water pump which I changed and all was good. Now just under a month later the pump is squealing so have had to send for a new one. Really difficult to pinpoint the culprit. Stops after a few minutes, thought it was the secondary air pump, disconnected that but still there, took the a/c belt off, no joy. Main belt and it stopped.
- Greydog
Coolant pump
Belt tensioner starting to go ?
Coolant pump
Thanks Henry noted , will see.how.it goes but will need sorted by winter or.it will be a cold sit
Annoying when you changed the waterpump and the noise is back soon after , I get a squeal on moderate acceleration often when I move off to get out a junction which disappers instantly If I lift off which I believe is the front rubber mounted main crank pulley , it doesn't wobble yet but I believe the rubber is slipping under high loads maybe something to look into for you as water pumps rarely give bother.
- henrym3
Coolant pump
Greydog the belt tensioner was checked, well, visually with a quick spin by hand and felt for play. Seemed good.
Leslie what you describe is exactly what mine is doing. First thing in the morning and a quick squeal if booted out of a junction. I leaned towards the pump because there is play in the bearings.
Coolant pump
Mine did it since I got it and its had a new pump in that time which isn't leaking .I only changed the pump as I had a leak which turned out to be a pinhole in the bottom of the rad but it was getting spray about while driving so looked like the pump. The pump did have a little play to though but was serviceable but when I was in that far and had a new one it was for the bin.
- henrym3
Coolant pump
Still not fully convinced that the problem is the pump. Replaced the small belt (compressor) idler pulley today, thought I’d cracked it because the bearings were done with about 1/8th inch of play. Didn’t make any difference to the noise. I’ve sent for the main belt idlers but I’m not confident on size. The ones fitted are 72mm diameter but RealOem says they should be 80mm on the 4.6is. Sent for the 80mm ones. We’ll see. This is the bearing I spun last week and didn’t notice it was on its last legs?? Maybe I had a dream I checked it. Anyway don’t mind changing the pulley’s they have done a few miles. Got a new set of belts as well. I suppose there will be a period now as it heads towards 200k where things are getting worn out just as they did at 100k
Coolant pump
Now my aircon is only blowing cold on the left centre vent ,possibly the left vent too cant tell while drving both right vents are room temp which is 27c these days and Im being cookedhenrym3 wrote: Sun May 31, 2026 10:06 pm Leslie, I had that heater problem with one side, it was the heater valve IMG_1493.jpeg
