HID kit
- kkodal78
HID kit
Or you can buy a headlight assembly with projector type lens in it and just swap it with a H7 kit directly.
You will have a great deal of glare from not having the projector. Unless you bought the H7 for reflector type headlight.
Re: HID kit
Hi, I have been working on my lights this weekend and can confirm the prefacelift has a plastic retaining ring with no metal clips, its a push and turn bayonet type fitting,
cheers crofter
cheers crofter
02 X5 3.0d Sport
Re: HID kit
have taken a photo of the new HID and old bulb. The hid is in my hand in the pic. its a lot bigger and will not fit where the old bulb was.
- Sanj
Re: HID kit
I see them - what you can't see them? Sure that surgery was just on the jaw. Happy pills, mmmmmmmmm.......
I'm kidding buddy, no pics, honest. O:-)
- kkodal78
HID kit
Here is the halogen comparison
Here is all 4 together
At the end eventhough i haven't seen H1 set up for X5 for dipped beam, looks like you have the wrong bulb kit or you pulled the main beam bulb by mistake
Re: HID kit
As above, that is a H1 and I'm pretty sure the dipped beam has always been H7. H1 I think is fog light.
- kkodal78
HID kit
i think the fog light was H3. i've changed the fogs on my friend's diesel prefacelift and that's what he had in there. i ordered the H3s for mine trusting that. if it is mot H3 on mine i have a few H1 kits sitting in my garage that i can use.
on the other note i hope you get the mix up sorted out.
hope we gave you decent amount if guidance
Re: HID kit
[quote="kkodal78"]
H3 is foglight, H1 is high beam... :-[
Re: HID kit
Looks like you've removed the inner (high beam) light bulb and not the outer (low/dipped beam) one.
- kkodal78
HID kit
[quote="Raj"]
confirmation on this statement will be a good relief.
Re: HID kit
Well you have all certainly been helpful than I could have imagined.
Thank you all. I have just checked the box an I have been supplied with a H7 kit. I will phone HID direct ASAP as when I ordered I specified on my order that the kit is for a 2001 X5. I was unsure of which kit to purchase and someone from hid direct sent me a link to this particular kit.
Thanks again all
Thanks again all
Re: HID kit
[quote="awj85"]
Thanks again all
Can you confirm was it the outer or inner bulb you removed from the headlight? As H7 is the outer low dipped beam.
Thanks again all
