How-To articles ONLY go here.
roland
Post by roland » Tue Apr 05, 2011 5:53 pm
Hello Fenj66,
maybe your circuit board is faulty.
it seems that your "original" Webasto worked previously, and the PCB failure is common with Webasto.
By changing some resistors on it, you could have a spare PCB.
check this link : http://www.the75andztclub.co.uk/forum/s ... 7b&t=53896
Also, I noticed that while using a PCB from an E39, you have to manually stop the AUX heater or it will continue to work endlessly.
nujon
Post by nujon » Sat Apr 09, 2011 12:37 pm
[quote=""fenj66""]just as an update on my own webasto problems as mentioned in this thread.
i have just acquired a second hand webasto circuit board from a pre facelift X5d. after using my scanner to clear away any fault codes in the system, the heater now runs ok from the pre selected timer option and the heat on button from the OBC and also from my own remote control (ie, after about five minutes the interior fan comes on to blow warm air at screen). i couldnt test if it comes on automatically at temps below 5*C as its too warm at the moment. so i am pretty happy now! :) it would point, as mentioned earlier, that the facelifts arn't compatible with enabling aux heat, unless parts are changed/upgraded. but a cheap s/h circuit board from an earlier X or E39 webasto might sort the problem out. hope this helps.. ;)[/quote]
Fenj - just to test my understanding, you have got your Webasto to work via the the OBD (timed and on/off) just by enabling with a 1.4.0 and replacing the heater's PCB - i.e. you have not fitted the 3rd water valve (or resistor substitute) or changed the H&V panel?
fenj66
Post by fenj66 » Sat Apr 09, 2011 6:10 pm
[quote=""roland""]Fenj - just to test my understanding, you have got your Webasto to work via the the OBD (timed and on/off) just by enabling with a 1.4.0 and replacing the heater's PCB - i.e. you have not fitted the 3rd water valve (or resistor substitute) or changed the H&V panel?[/quote]
hi, yes thats correct, i have done nothing else other than fit an older circuit board to the webasto to replace my fried one.
i might try and fit a resistor in place of the 3rd water valve at some point and see what happens out of interest tho.
wilkoturbo
Post by wilkoturbo » Sun May 01, 2011 9:44 pm
Can I enable heater option on my nav screen via DIS or SSS ???
Many thanks
Paul ::)
bmw x5 le mans blue
wilkoturbo
Post by wilkoturbo » Tue Jun 14, 2011 7:31 pm
Here how to activate with DIS v57
All done !!!
bmw x5 le mans blue
malc1950
Post by malc1950 » Thu Sep 08, 2011 5:54 pm
Hi waka, is your 2004 x5 a e53 facelift , as my car is and i am trying to enable my wabasto heater, malc1950
2004 3.0d Sport Facelift Remaped, Schnitzer styling body kit, Black leather
Neon lights, Elec fold in mirr, 6Cd changer,DSP, Sat nav, Bluetooth, Wood pack
Speed camera warning, Heated front seats, Wabasto heater, Auto wipers lights,  Rear view camera.
wilkoturbo
Post by wilkoturbo » Thu Sep 08, 2011 6:40 pm
Would this work :) 270750084242
bmw x5 le mans blue
Rusty
Post by Rusty » Thu Sep 08, 2011 6:59 pm
[quote=""wilkoturbo""]Would this work :) 270750084242[/quote]
As there is no information, I wouldn't like to say.
Maybe try asking them a question re functionality :rofl: and see what they come up with in Chinenglish
I like the look of the unit though and may even order one myself to check it out. Worth a punt at that price mate. :thumbsup:
Runabout - E92 3 Series Coupe
evoblue
Post by evoblue » Fri Sep 09, 2011 7:01 am
You need to check that the output will latch for a variable amount of time or you will be getting in the car soon. If the output latches continuously then your heater will run all the time until you tell it to stop again with the remote. I have one that latches for different time periods. I think it was 5, 10, 15 min etc. That way it automatically stops the heater and you dont have to switch it off yourself. The wabesto remote does this but very expensive due to it having another control box.
wilkoturbo
Post by wilkoturbo » Fri Sep 09, 2011 9:42 am
By the sound of it just on off with a press of the remote fob , what is the spare plug for behind the WebO ?
bmw x5 le mans blue
evoblue
Post by evoblue » Fri Sep 09, 2011 10:10 am
Reading the spec it does say about a latch. That company also had another one no 270790706799. states the output type as The output style:
Self-locking, Non-locking, Interlock
I presume they are latch non latch and not sure what the interlock is. The latch would certainly hold the 12v on the terminal.
I dont know what the other terminal on the heater is for. I am sure somebody will.
malc1950
Post by malc1950 » Wed Sep 21, 2011 6:59 pm
Hi evoblue ordered my scanner off ebay 3 days ago will let you know how i get on , Malc1950
Waka
Post by Waka » Thu Sep 22, 2011 5:10 pm
hi malc1950,sorry I missed your previous message.
Let me know how you get on, if you get any problems I'll try and help. Although it was quite a while ago I did mine! It's quite straightforward anyway.
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
malc1950
Post by malc1950 » Mon Oct 03, 2011 5:19 pm
Got my scanner from China today will enable the heater on the obc this weekend, fingers crossed ! :D
malc1950
Post by malc1950 » Mon Oct 03, 2011 5:25 pm
Hi Waka will let you know how i get on this weekend, 8-)
