Hello from new owner
Micevo
Post by Micevo » Thu Jul 02, 2015 11:02 am
Hello
I've just got a 2002 X5 4.4 in black, had it about a week now and love it , a few annoying little issues but what can you expect from a 13 year old car!!
Had a V8 jeep grand cherokee before this but just fancied a change, now the jeep seems old and dated lol but only a years difference in age.
Hopefully I can sort the issues will post them on the problem bit and can maybe lead in right direction,
  Mic
Reusch
Contact:
Re: Hello from new owner
Post by Reusch » Thu Jul 02, 2015 6:45 pm
Welcome Mic,great when there running ok,now let's have a guess what's your little issues are with it.Ill start the ball rolling.
Squeaky suspension.
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Post by AW8 » Thu Jul 02, 2015 7:54 pm
Welcome to the site.
I also run a 2002 X5 4.4i and have done so for 9 years.......Unsure if this is a positive testimony to the car or indicative of my insanity - anyway I hope you look after it, treat it with some respect &/or at least keep it more than 5 mins.
Happy to assist re any issues or likely future events (subject to my memory)
Good Luck :)
lezmtaylor
Post by lezmtaylor » Thu Jul 02, 2015 7:58 pm
I hope you have as much fun as I have with mine, 2002 4.4.
Had it 9 years, still love it.
Lez
Post by AW8 » Thu Jul 02, 2015 8:06 pm
If memory serves me correctly it's myself Lez  & sapphireblack who have been in for the long haul with  our pre facelift 4.4i's.
If anyone else can claim 9 years or more in a V8 E53 please declare your bravery or stupidity here ;)
Micevo
Post by Micevo » Thu Jul 02, 2015 8:12 pm
Thank you for your replies
Suspension all been done have checked and all new bushes which is a result,
I may just take you up on your knowledge
Post by AW8 » Thu Jul 02, 2015 9:49 pm
I dont need prompting more than that......
Firstly dont worry re what follows - all or most may not currently apply to your vehicle !
On a prefacelift V8 the sensible checks I would make might include.....
Examine visible belts & hoses, keep regular check on coolant levels,  check for  expansion tank and bleed screw integrity on top of  same plus keep eye out for any early water pump leaks (not common but these can be expected to need changing by 100-120k), If plugs have been in more than 5 years at least remove and carefully clean the threads maybe using a very little graphite grease to same (they can seize- especially if water has got in there at some point).
Get engine cover off & check PVC hose integrity (rubber hoses across top and rear of engine). Look for signs if recent  and significant rocker gasket leaks. Keep eye on pas high pressure hose. Keep eye on fluid levels including engine oil & get it changed unless you can be satisfied it was last serviced by someone sensible.
Oh & try to be nice to the gearbox - kickdown arguably places some additional strain on box - especially  if executed prior to vehicle being warmed up. Worth checking gasket to auto box sump for signs of leaks too.
If you have a partner they may not be too excited to learn of my car health check tips -  disclosure of above at your risk.
Hope some of above helps. Apologies if some of above is common sense stuff, does not apply to you and/or your car.
Micevo
Post by Micevo » Thu Jul 02, 2015 10:35 pm
Yea thanks for that info have had it on a set of ramps and checked all underneath all looks good will check the psv ( didn't know about that or the high pressure hose) all oils will be changed in next couple of weeks , and like said just general maintainance to try am keep on top of it, I appreciate your help an will defiantly adhere to it,
Mic
Post by AW8 » Thu Jul 02, 2015 10:39 pm
Glad of some interest........give us a shout in any issues or queries.
Good cars these if kept on top of.
