When is select Reverse gear (2004 E53 3.0D) the rear pdc alarm starts beeping.sometimes it is random sometimes it is a the usual intermittent beep, sometimes just continuously on when in Reverse. All sensors have the clicking sound coming from them and I ve cleaned any crud off them
Can I diable the sensor. With bmw scanner 1.4.0 or in some other way. or clear/reset them?
thoughts?
Smee
Can i disable PDC
Re: Can i disable PDC
You need to plug in and find the faulty sensor
- fenj66
BMW scanner 1.4.0 can disable front or back banks of sensors.
buy one of these,its as essential as a jack and wheel brace these days,will tell you exactly which sensor is duff,replace it and keep your pdc working.Will reset warnings and also displays live running conditions,temps,pressures etc
http://www.ebay.co.uk/itm/C110-Scanner- ... SwLVZVuwyC
Thanks but no I don't need to do that, as stated above I have the 1.4.0 and will use that to look on their to see if it throws up a fault. If not then I will disable rear for now (thanks to Fenj for that) as I have a specific reason for needing it disabled (or fixed)
That said each one appears to be working perfectly as you approach an obstacle - the sensor beeps comes on as soon as I hit reverse, and noticeably it stays on when driving away in D until I hit the pdc button on the centre console
This makes me think the fault is there and not with any individual sensor
Smee
Smee
