Hi guys,
Managed to get a headlight but there's one ballast missing. Any ideas where I can get one from.
Xenon headlight Colour of light wierd!!
Re: Xenon headlight ballasts
Could try these
http://www.hids-direct.co.uk/categories ... D/2001-06/
I've linked to the e53 but you don't say which model you have so may need to change search criteria.
05 Mercedes SL350
05 Mercedes SL350
Got the ballast from the stealers in the end. £90 so not too bad. Problem is one the lights is purple whilst the other is normal white! Any ideas anyone?!
Re: Xenon headlight Colour of light wierd!!
It could be that youve got 2 different bulbs in there. Ie the colour temp. I think the standard ones are 4300k , but some people fit higher versions 6000k and above..The higher the k figure the blue,er the light...
Dave W.
BMW G05 X5 40D
BMW G05 X5 40D
- Steamyrotter
It is usually best practice to change ballast and tubes together.
Chances are once one has gone, and it hasn't taken the other out, it soon will!!!
I know this is not technically what you were initially asking, but might save you in the long run.
The light has two led repair kit modules, look like spikes on the underneath of the headlight. I tried swapping them around n the purple tinge moved over so the issue is definitely to do with the module. It's £200 from the stealers! They reckon too it's in its way out so looks like it's another £200 gone!
