I have tried accessing the hidden menus as outlined here:http://www.scoopz.com/m5board/E60_Hidde ... ctions.pdf
However, when I enter my totalled up chassis numbers, I can't get in. My chassis number is 292960, which by my reckoning comes to 28. Do I ignore the 0 on the end or do I have to add something?
Hidden menu question.
Re: Hidden menu question.
Has anyone done this on their E70?
This does work.....I've used it mine many times.
Sent from my SM-G900F using Tapatalk
X5 E70 3.0D SE
[quote="pcdee"]
Do you mean the E60 instructions above? I've tried it and can't get in hence my question about the
chassis number combination. Any help would be appreciated, thanks.
- DiscusbT
I can only add that it worked on my e61, and it works on my f25. You do have to get the timing and sequence exactly right otherwise it doesn't work. Logic would suggest that if you have a 0 in the number that is what you add.
