Hi,
I think the air suspension bag on my relative's 4.8is 2006 has gone.
All other corners pump up, except the drivers side.
It pumps up, but then a hissing sound can be heard, and it lowers on that 1 side.
http://www.realoem.com/bmw/enUS/showpar ... Id=31_0690
would the airbag part number be: 37116761444 ?
Seems very expensive.
would the following be ok:
http://www.ebay.co.uk/itm/Front-Right-A ... Swa-dWkHoo
is there anything else that needs changing (recommended)?
inactive air suspension
Re: inactive air suspension
Is it deffo the bag and not a hose/pipe/connection? Might be worth a look before splashing out on a new bag.
2005 X5 3.0d Sport
and a new Gearbox :'(
- ianst0028
spray water on the bag and pipe while it's inflated then watch for the bubbles while it deflates
X5 e53 3.0 2002 with LPG
Ok, is defo the bag. Can someone recommend a front passenger side and front driver side bag?
Ideally i just want to get the part, take it to the local garage and tell them to swap the bags over.
Sent from my LG-H850 using Tapatalk
Or is it wiser to install coilovers such as http://www.ebay.co.uk/itm/221990321080
Then would i simply need to deactivate the active air suspension using bmw scanner?
Those look good. Assuming a DIYer could change the air bags over?
- ianst0028
I've done them on an audi allroad ..... only advice i'd give is pull the fuse or relay to stop the pump going (not sure if it needs the key in the ignition on the x5 it didnt on the allroad)
apart from that its pretty easy
