Serpentine belt service interval
Smeeagain
Post by Smeeagain » Tue Nov 28, 2017 7:53 pm
Can anyone tell me for an 2004 E53 3.o D Auto when the serpentine belt, as I believe it is correctly called, i.e. the one that drives the alternator, water pump and power steering pump, should be changed? I don't recall seeing any posts about this previously.
Smee
Re: Serpentine belt service interval
Post by X5Sport » Tue Nov 28, 2017 9:24 pm
I don’t th8nk that I have ever seen reference to it either.  Treat it like a timing belt would be one approach - say every 60,000 miles/5 Year’s?
Not had it done on any of our BMWs - mind you they are all <60,000 anyway.
My X6 is in on Friday (winter tyre changeover) so I’ll try to remember to ask.
sleepyfolk
Post by sleepyfolk » Tue Nov 28, 2017 11:32 pm
If you don’t know when they were last done just change them anyway, ECP have got Continental belts for very little money, I think both the belts for mine were less than £30.
Not sure if I read that 4 years or 100k was a guideline, might be wrong but seems reasonable!
Mercedes CLK 320
Audi A6 Quattro 2.4
Smeeagain
Post by Smeeagain » Wed Nov 29, 2017 8:24 pm
So to your point then, i don't think mine has a timing belt but does have a chain (and presumably with a tensioner) - any guidance on if/when the chain/tensioner should be changed bearing in mind that my car as you know is quite high mileage...?
Post by X5Sport » Fri Dec 01, 2017 3:48 pm
Checked with the Dealer.....
There are no specified replacement intervals for the serpentine belt(s), however it (they) is/are inspected at each service and will be replaced if in poor condition.  Some cars have more than one apparently.
Timing chains will normally only be replaced in the event of a problem (such as a failed tensioner).  They are normally left alone for the life of the engine and never need doing.
Cam belts are a very different approach, with some being done every 30,000 miles (depending upon engine and usage).  Cam belts are far more likely to snap!  When I worked with Surrey Police we replaced those fitted to the Ford CVH series engines of the mid-80s every 3,000 miles after a spate of premature failures destroyed certain 1600 FWD engines.  I still think of those belts as very bad technology.
Smeeagain
Post by Smeeagain » Sat Dec 02, 2017 6:21 pm
So apologies if this is a daft question - does an E53 2004 3.0 D Auto have cam belt?
Smee
Post by Horizon » Sat Dec 02, 2017 6:59 pm
https://postimg.org/gallery/2q744ceye/
Images from real oem, one for the timing chain, one for the serpentine belts that drive Aux equipment i.e. Alternator power steering AC etc
Post by X5Sport » Sat Dec 02, 2017 9:00 pm
BMW only use chains on the E53.
