Rear air suspension
Zedhed
Rear air suspension
Post by Zedhed » Wed Dec 27, 2017 11:38 am
Hi folks,noticed that when someone gets in or out of the back seat,i hear the compressor start to run but doesent really seem to raise or lower.can anyone tell me if should.
Re: Rear air suspension
Post by Alan Gunn » Wed Dec 27, 2017 11:48 am
Mine does that sometimes just for a few seconds about 10 or might be 5 don't take any notice any more.
Car sit's level so i don't see any problem with it.
snrbrtsn
Post by snrbrtsn » Wed Dec 27, 2017 12:11 pm
It’s pretty normally, though shouldn’t be overly loud
If concerned, jack up the rear and with a soapy solution spray the airbags to check for signs of perishing!
The wear pattern will be front most side at 10-2 o clock area, if you consider the front of car is 12 o clock
I was surprised when I had to change mine, nearside rear, relatively simple DIY, shouldn’t  take more than an hour (conservative) my bag was perished and cords showing (typical BMW & N/s affected)
There is a couple of do’s & don’t if changing
Disconnect air from compressor side, this will require removal of undertays to gain access
Once complete & all buttoned up, Lower the car but keep its weight on jack, ignition on / run the engine to have compressor inflate the bag, only once inflated, do you lower the car
(Otherwise you overload the compressor & burn out)
I’d explain the simplicity of change out, however it’s best described on Arnott website
http://arnottinfo.com/manuals/A-2642.pdf
BMW price £440 to change
Zedhed
Post by Zedhed » Wed Dec 27, 2017 7:45 pm
Suppose if one was leaking or anything the car would not sit level but sits level all round.
snrbrtsn
Post by snrbrtsn » Wed Dec 27, 2017 10:14 pm
Very true, I’d suggest it’s a normal trait of the system working as it should and correcting the ride height
Post by Horizon » Wed Dec 27, 2017 10:26 pm
[quote="Zedhed"]
X5 Salisbury had a problem with the exhaust port on The air suspension valve block not sealing so letting air escape, so allowing the suspension to sag overnight .
He researched this and found a solution involving silicone spray to be the answer.
Worth spraying the bags with soapy water as well to see if the airbags are gone too.
Zedhed
Post by Zedhed » Thu Dec 28, 2017 9:07 am
Ok bud,think i will do.
X5-D-Sport
Post by X5-D-Sport » Thu Dec 28, 2017 1:12 pm
Hi there, re the Air suspension, if you still have issues with it, by all means private mail a mobile number to discuss the problem & we can post it here when fixed.
Post by henrym3 » Fri Dec 29, 2017 12:12 pm
I recently fitted two new air bags and it still gives a 2/3 second burst as I reverse out of my drive because it is an uneven surface where it joins the road. BTW not the reason I had to change the bags. The odd burst of air from the compressor is pretty normal.
VW R32 Gone
