BMW X5 e70 bad mpg 2007 30d
Ryanleady
Post by Ryanleady » Wed Jul 24, 2019 8:32 pm
Can anyone help I am only getting 16.5 mpg out off my 3.0d and I am driving it normal not dring it hard I read up I should be getting at least 20 to 25 mpg around town Does anyone have any ideas what it could be or what I can change it has just had a service by the garage I got it from they did only do diesel filter, oil filter and oil change
Alchemist
Re: BMW X5 e70 bad mpg 2007 30d
Post by Alchemist » Wed Jul 31, 2019 4:46 pm
has the thermostat been checked? If it's stuck open the engine won't be heating up properly, this caused a drop of 3-4mpg in my E46 3.0D.
You may need software to check though if your X5 doesn't have water temp on the dashboard clocks (as i think none do)
LincsX5
Post by LincsX5 » Fri Aug 02, 2019 3:54 pm
As Alchemist said probably thermostat. My MPG had dropped off and after some Google’ing I checked the coolant temp on a run and it was low. You can check the temp in the hidden menus (Google it) if you haven’t got diagnostic kit. I changed both thermostats, not a big job, and all was good again. Mine settle at 26.4 mpg using it on a daily 13mile commute across the city.
pcdee
Post by pcdee » Fri Aug 02, 2019 4:38 pm
I get 27.1mpg around town.
Definitely get the temp stats checked, if they don't get up to temp it'll affect the DPF regeneration.
Post by Graeme » Fri Aug 02, 2019 4:49 pm
Just collected my car after heater plug recall. All computers reset to 0. Five mile drive home at 3:30 pm with stop start, traffic lights, roundabouts etc. 18mpg!!!! Car normally does 28 overall and 34 on motorway run. And yes, new thermostat fitted and DPF regenerated a few months ago!
Jayx5
Post by Jayx5 » Fri Aug 02, 2019 8:45 pm
I've had both of my stats changed about 4 months ago and it's doing 22.2mpg at the moment but its pulled a caravan from essex to dorset but it never gets above 24 :x
Jayx5
Post by Jayx5 » Fri Aug 02, 2019 8:46 pm
