Hello all,
I'm in Surrey and I'm looking to get a Westfalia detachable towbar fitted.
I was going to do it myself but this dashed idleness keeps getting the better of me.
Can anyone recommend a good towbar centre or mobile fitter in my area?
UF
Towbar fitters. Can anyone recommend any?
- UrbanFlow
Current Rides:
2007 Black X5 E70 3.0D SE - 7 Seater, Dynamic & Media Packs
1975 MGB Roadster with Rover SD1 V8 conversion, Offenhauser Manifold & Holley Carb - Straight lines only.
2005 Honda Hornet with Akrapovich zorst & other odds n sods.
Previous Ride:
2003 Silver 3.0i Sport E53 X5
Previous Ride:
- B5tew
Re: Towbar fitters. Can anyone recommend any?
Hi UF
Do it yourself takes about 5 hours and is relativley easy I had quotes from mobile fitters of £650.00+ for a Witter and got a Westfalia delivered from PF Jones for £369.00 including a dedecated kit the hardest part is wiring up the trailer module as you have to remove the plug in the car and solder on new terminals but the instructions are easy to follow.
Did mine the weekend and would not hesitate to do another.
Good Luck
Stewart
Good Luck
Stewart
2015 Space grey 30d F15
- wilkoturbo
Hey do it yourself It I did mine in about three hour
but with no soldering I had the 13pin socket tho plus trailer ecu cost 369.99 all in
bmw x5 le mans blue
- UrbanFlow
Thanks for the replies. It all sounded so good until you said 'soldering'!
I'm pretty hot with DIY car work, but I have to say, I've only soldered once with average results.
I thought the Westfalia wiring was plug and play for some reason.
I've seen a step by step guide to fitting the detachable bar on another site and it looks like a relatively easy, but time consuming job.
Current Rides:
Previous Ride:
Previous Ride:
- wilkoturbo
Yes that's mine plug and play ur right
bmw x5 le mans blue
- B5tew
The wiring kit I got was made by Right Connections the trailer module came with crimp connectors I only soldered them for my peace of mind although at the time I did wonder why the manufacturer didn't make it to just plug into the socket you have to cut off. Still easy though just pair up the right colour with the right number on the socket.
