BMW E70 Rear axle Air suspension
Greydog
Post by Greydog » Thu Sep 24, 2026 8:09 am
About 3 weeks ago I started to get an air suspension issue, the compressor would over run and timeout. There are no leaks as I pulled the compressor fuse to protect it and the car will sit for a week or more without dropping.
So finally got some time to check over the system, I started with a visual check of wiring to the rear sensors and tested continuity between the EHC connector and sensor plugs (had an issue there before) I found nothing this time. So replaced the fuse and plugged in the diagnostics, the compressor ran and raised the suspension far to high on the left, right didn't move the compressor ran until it timed out. Diagnostics showed 4 codes 5F94 Solenoid valve Left 5F95 Solenoid valve Right 5F96 EHC Drain valve 5F99 Control time fault rear right.
Talked to an old friend who works for BMW who asked their technical department sadly they couldn't offer any help as their solution is replace the compressor complete with solenoid block and sensors (and BMW prices that's nuts)
The compressor is easy to remove from the car so off it came and I serviced it, checked the dryer wasn't wet, took off the drain valve cleaned it and tested the solenoid vale was functioning did the same with the solenoid block all OK so back together and on the car
Compressor runs and lifts the car to above standard height and again over runs and times out !!! Now I only have one code 5F99 Control Time Fault rear right
So I have changed the rear right ride height sensor (New correct part number) and run live Data Left rear sensor shows 5.02v and ride height +20mm Right rear sensor shows 5.04v but -127mm ?? Yet when measured at the wheel rim to wheel arch ride height is 750mm (should be 720 to 730) I can manipulate ride height (lower/raise) through ISTA my problem is I can't clear the right rear sensor which constantly reads -127mm that I believe is the reason for the overrunning compressor which if left will burn out?? Sorry for War and Peace
Any body got any ideas or experience of similar all help gratefully received it's hurting my old brain now
BMW E70 Rear axel Air suspension
Post by X5Sport » Thu Sep 24, 2026 10:04 am
Shooting in the blind as not come across this…..
Is there a calibration procedure to ‘teach’ the car/system about the new sensor?
Was the new sensor OEM or a copy part? Might be a faulty sensor?
Post by Leslie » Thu Sep 24, 2026 12:46 pm
Broken sensor wire somewhere along follow it back id say as a guess
Greydog
Post by Greydog » Thu Sep 24, 2026 4:22 pm
Hi guys
Thanks for the input
Leslie. I have checked visually then carried out a continuity test on both the left and right sensor wiring between the EHC Connector and the sensor plugs, they both check out OK so not a broken wire. Also checked power both are receiving the correct 5v just checked again to be sure.
X5Sport. I have both INPA and ISTA and yes there is an Adjustment/Calibration routine which should be followed after any changes to the suspension, as the right hand sensor has been changed I did run the procedure. The new sensor is Hella (OEM supplier) and supplied to the correct part number so should be OK. However tomorrow I will swap left for right if the issue moves it should confirm whether the sensor is OK or not I will also carry a test on the old sensor.
Thanks Chaps I will carryout more research stir the old grey matter it is a simple system why is it being so obstinate :rofl: Time for some headache pills or may be a beer will help
Post by Leslie » Thu Sep 24, 2026 5:10 pm
Can the little link rod flip backwards on these giving odd readings ? Id disconnect the little rod and move it up and down and see what the feedback shows and if its moving as the arm moves .
is the left reading +750 and the right -127 ,is that correct , does the right stay the same even when unplugged ? I wonder if that is some default valve as it im guessing should not be minus ? sounds like it isn't getting any actual feedback .
The left to right swap is the next step like you say :thumbsup:
Greydog
Post by Greydog » Sat Sep 26, 2026 8:15 am
Morning Leslie
Correct Left rear sensor live Data shows +750 (thats 20 to 25 mm high) right rear sensor shows -127 even though physical measurement shows the rear right ride height to 736 the minus 127 reading is what triggers the compressor Looking back through the cars history Sytner Luton carried out the last Dealer service and replaced rear sensors. That was in 2018 and before my ownership, in my ownership I experienced a suspension issue about 2 years back which I traced to the rear left sensor wiring which had been repaired with a poorly crimped joint. I remade the joint with a soldered joint and all good until now.
The only thing I have found is for some reason the activating rods for the sensors are different lengths Left 71.5mm Right 81.4 mm ?? Why I have no idea. However my car has equal length either side (71.5 mm both sides) so I have ordered the right hand activating rod from Vines in Crawley If I can get the car back to OEM I may have a chance to find the culprit, my thinking at the moment is the EHC control unit or an issue with the FRM (I do hope it's not the FRM)
Post by Leslie » Sat Sep 26, 2026 10:28 am
The left being out will be due to a correction valve in the software to try and get it to the correct height and I don't think that will be an issue , the link arm being the wrong length needs sorting first but there is another issue for sure. Id check the ehc unit hasn't got wet or for any signs of water damage , I wonder would a used one need coding ?You have the software to sort it anyway .
Greydog
Post by Greydog » Sat Sep 26, 2026 3:42 pm
Hi Leslie
My understanding is that the EHC is set at the Factory dependent on the cars set up which wheel/tyre package (18" 19" 20" 21") so as most E70's in the UK are on 20" wheels that is always a possibility a second user EHC will be OK. If the EHC is changed (old or new) I would go through the adjustment/calibration process anyway.
Part is due Tuesday they tell me so I will know more once it is on the car (fingers and toes crossed)
Greydog
Post by Greydog » Tue Sep 29, 2026 5:05 pm
Well picked up the sensor actuating arm from my local dealer and fitted it with the new sensor, result not one bit of difference :headbang: The cars suspension sits level and at the correct height, it doesn't leak as I have been driving it for a week with the Compressor fuse removed and it hasn't dropped any. If I replace the fuse the compressor will run and time out, Diagnostics still give the same sensor reading for the right rear sensor -127 the confusing thing is the suspension sits correctly
The only logical next step is the EHC, just checked on line and there are a few not to expensive so will give it a go, if that makes no difference it could be an issue with the FRM. When carrying out the diagnostic both the EHC and the FRM show fault status in the Control tree which I assumed was due to the sensor fault
More head scratching needed that or more beer
Post by X5Sport » Tue Sep 29, 2026 10:09 pm
It’s definitely not a wiring issue? No wildly different resistance readings between the two cables when disconnected from end to end?
Post by Leslie » Wed Sep 30, 2026 7:19 am
Im sure you have checked the pins on the cable for corrosion or one being pushed back as it still does sound like the signal isnt getting through .
Greydog
Post by Greydog » Wed Sep 30, 2026 7:30 am
Morning X5Sport Thanks for the input
Well initial continuity tests I carried out didn't show anything but I have nothing to lose by going back to basics and starting again. I admit I only tested continuity not resistance so guess what I will be doing later :wink:
I talked with a Local BMW Specialist who I have used he was very helpful and has given me a few things to try, but like me he is confused by the reading I get from the sensor, his opinion is it is definitely the cause of the overrun on the compressor.
At least I have a test lead made up and everything is reasonably easy to reach plus I have practised a few times :rofl:
Greydog
Post by Greydog » Wed Sep 30, 2026 7:42 am
Morning Leslie
The BMW Specialist I spoke with his first thought was corroded pins on the sensor or EHC. The sensor is new and correct part number I still have the old sensor and have swapped them with no change The pins on the EHC look to be OK and I have used Contact cleaner on both pins and connectors
Back carrying out more tests later
Greydog
Post by Greydog » Fri Oct 02, 2026 11:52 am
Progress so far
Carried out further continuity and resistance tests which fortunately show the wiring is not the issue. Spoke again to my friendly BMW Specialist allowed him remote access through ISTA so now he is as confused dot com as I am :rofl: His conclusion is the EHC has an issue, so I have a replacement ordered
Greydog
Post by Greydog » Tue Oct 06, 2026 8:25 am
Quick update while waiting for the new EHC to arrive I carried out more research it seems there are a number of Sensor suppliers Hella Arnott and Aerosus being the principle names and all manufacture in China. The sensors fitted to my car are Left ride height sensor Arnott traced by the manufacturer number then cross referenced to BMW part number the Right hand one that was on the car when I brought it has no branding or marking that I can find (but has worked fine until a month ago) and neither does the New replacement
If the New EHC doesn't do it I might put the damn thing on springs :x
