MID Radio
- Sanj
Re: MID Radio
If you can go through the laborious task of identifying the colour of the wires I might be able to help. I did this from the amp in the boot when messing with an aftermarket unit. Could be the same...
Re: MID Radio
Do the speaker wires go the the boot?
- Sanj
Re: MID Radio
Yes - to the radio module, also known as the BM24 or BM54. Under the boot floor, spare, compressor and the plastic housing surrounding the battery.
Re: MID Radio
Where is the radio module?
Thanks.
Thanks.
- Sanj
Re: MID Radio
[quote=""Sanj""]Yes - to the radio module, also known as the BM24 or BM54. Under the boot floor, spare, compressor and the plastic housing surrounding the battery.[/quote]
[quote=""mas123""]Where is the radio module?[/quote]
In red buddy...
In red buddy...
Re: MID Radio
Hi,
I just want check before I take the spare wheel out, do the speaker wires go to the radio tuner or can I access the speaker wires from near the CD changer? I don't have DSP.
- Sanj
Re: MID Radio
Source is the radio module, not sure which way your loom will then go. Best to go from the module.
What are you trying to do? Replace the HU?
Re: MID Radio
Hi,
I am trying to take some connections of the speaker wire so that I can connect an amplifier.
Thanks.
Thanks.
- Sanj
Re: MID Radio
In that case use the search option above and you'll find posts like this (links to YouTube):
viewtopic.php?f=22&t=1412#p15347
Think you'll have most questions answered.
Re: MID Radio
Hi,
There are three plugs going to the radio module one them is a black plug with 6 wires which includes brown orange stripes red/green and white with orand stripes. Are these the speaker wires
Re: MID Radio
There is a plug head 'AMP' can I use the wires from that plug?
Re: MID Radio
Hi,
I checked the videos on you tube and they assume the car a a subwoofer it all ready and take the connections for the amp from there. Does anyone know whether the plug in the back near the radio module marked 'AMP' is the same plug that I can use for connecting a active sub?
- Sanj
Re: MID Radio
I haven't looked through this fully, mine is a HK unit but does this help:
http://www.xoutpost.com/articles/x5/ste ... y-amp.html
