Well i'm just over one week on with the new X5
All still running well.
We had a family trip out to the seaside, loving the V8!!
Still managed 22mpg even with a few overtaking manoeuvres
Jobs wise i've managed to polish out the 6" scratch on the rear quarter. I first used Farecla scratch paste which got rid of the scratch but left it a little hazy. Then some Meguiers Scratch x. I've never attempted this kind of thing because of my experiences of T-Cut (many years ago) Well this really worked! I'm lucky as the scratch was just in the clear coat but made a horrible white line down the car. Wish i'd taken some pictures now.
The bumper still needs spraying, no magic polish will fix that - i think £120 + vat i was quoted . May have to wait a little while as i have tyres to pay for.
Audio
It turns out the car had an iPod system fitted. There was a horrible bracket attached to the dash with broken wires sticking out of it. Luckily all i had to do was remove the Nav screen and undo the bracket, pull the wires through and disconnect at the cd changer end. I was expecting to have to buy an adapter for my ipod/dice as my car has dsp. The standard wires were there so i gave it a try and it all woks fine, dsp as well.
TV & Nav
This is where i could do with a bit of advice
The screen has an flicker every so often. After checking the web i suspected the trafficmaster unit so removed that from the system and although the screen definition is now better i still get the flicker.
When i first bought the car the television function was greyed out on the display, one day it sprung to life now it's disappeared. I guess the flicker issue could linked to this as well.
Is there a way to bypass the TV module to check? Or should i start looking to ebay?
Then of course do i try get a digital one ?
The nav itself works perfectly. this is just a flicker not a re boot.
Any other ideas?
One Week On - Report and a few questions
- Phil D
2003 E53 - 4.4i Black with Black leather, Bluetooth/Sat Nav & Factory Xenons
- Phil D
Re: One Week On - Report and a few questions
A replacement TV Module from solved the problem, no more flicker and for now analogue TV
I'll have a look into the replacement digital tuners at some point.
